Need Rear Bumper Instructions
I need to remove my rear bumper skin, does anyone know if it is straight forward or if there if a procedure published on the web? Also I want to plug the plate holes on the front bumper and move the plate down low, has anyone done this?
Lifetime Member
Lifetime Member
Pookee,
I have not done this myself, but sort of have a general idea.
First you will need to remove all the rear lens (signal and the center lens), take a look at the DIY page of my web site for the Rear Fog light install section for procedure on how to remove the rear lens. Because the rear lens sits on the rear bumper cover and there should be some screws that you will need to remove that secures the bumper to the frame. And then here are some more bolts on each side of the bumper where it bolts up to the rear fender next to the muffler.
Hope this would help
