Odd (uneven) Ride Height...
Kim, the front should be a bit lower than the rear. You have Bruce Anderson's book, right? Take a look at the section on suspensions and right hide.
That said, my car was really skewed corner to corner, particularly after putting the H&R coilovers in. I now have the fronts even and the rears even (side to side) with the fronts about 1/4" lower for that slight bit of downward rake, but I had to adjust spring perches to a difference of almost 1" left to right to get things right. I HAVE NOT done a cornerweighting exercise as I was more concerned with appearence than cornerweighting in this case. Who knows, maybe having one corner 1" higher than another would have had decent cornerweights. Most race shops will tell you that cornerbalancing a street car can lead to some corners being higher than others.
I'll take measurements of my car tomorrow.
I should also add that I'm pretty mechanically inclined; even so, the adjusting / readjusting took about two hours to get the ride heights evened up. Changing a particular corner can have unintended consequences on another corner.
Don't measure ride height using the fenders as your guide. There is a spot under the car that you use. I can show you were it is better than I can describe it. I think that it is the bolt where the sub frame is mounted to the chassis. Our cars where put together by hand and their will be some variance in the bodywork.
OR... you can get the shop to corner-weight it for you. Since the front struts are height-adjustable, you can adjust the FL & FR corner heights independently. You don't want a majority of the weight on one diagonal (FR & RL, for instance) than along the other diagonal.
That'd be more important to me than consistent heights around the perimeter. But if it's strictly a street car, this isn't as important an issue as it would be at the track.
How new are the shocks
about two weeks after I took delivery of my cab, I noticed the car was definitely higher on one side. Just like you, about a 1/2 inch.
I freaked -- thought it had been damaged in transit.
After not getting a satisfactory answer from the dealer I called Reno - it was '97.
they said wait a few months, then measure. It even now.
M in C
M in C
Hi Silver Bullet...some good news! Your 993 is very likely perfectly 100% normal in ride heights with the drivers side being about .5" higher than the passengers side. This is normal as when you measure the 911 when you are not seated in the drivers seat......the ride height goes up as your WEIGHT is not in the car compressing the drivers side springs. IF you get in the 911 and have someone measure the car's ride heights most probably everything will be equal.
All these cars exhibit this characteristic unless you have "super stiff" 900- 1500LB competition monosprings in which case a 200+ driver wouldnt depress the drivers side springs very much. I hope this helps. Have a great day.
joe Fabiani Fabspeed Motorsport
Fabspeed Motorsport USA
155 Commerce Drive
Fort Washington, PA. 19034
www.Fabspeed.com
P: 215-646-4945
F: 215-646-9828
Exotic Car Performance Experts
Porsche, Ferrari, Lamborghini, McLaren, Maserati, Bentley, Aston Martin, BMW, Audi and Jaguar.
31 year PCA Club member supporter
14 year Ferrari Club member
1st ever financial supporter of Porsche Fans/ Rennlist
155 Commerce Drive
www.Fabspeed.com
P: 215-646-4945
F: 215-646-9828
Originally posted by 993 RS Clubsport:
<STRONG>Hi Silver Bullet...some good news! Your 993 is very likely perfectly 100% normal in ride heights with the drivers side being about .5" higher than the passengers side. This is normal as when you measure the 911 when you are not seated in the drivers seat......the ride height goes up as your WEIGHT is not in the car compressing the drivers side springs. IF you get in the 911 and have someone measure the car's ride heights most probably everything will be equal.
joe Fabiani Fabspeed Motorsport</STRONG>
RNH
Originally posted by Robert Henriksen:
<STRONG>Since the front struts are height-adjustable, you can adjust the FL & FR corner heights independently.</STRONG>
On another note, my car also has about a .5" height difference where the fronts have more of a gap in the fenders than the rears. I also have a C2S with M030 ROW suspension and 18" wheels. I was told by my tech that there is nothing that could be done about this. Sounds like this might not be true. Also, can cornerweight balancing be done on this suspension, I thought you need a fully adjustable suspension to balance all four corners.
Thanks, I really want to get my car right if it is currently wrong. These alignments aren't cheap. And finding someone who really knows what they are doing, and will do it well is a difficult task.
You have received some great advice in the prior posts. The quality in general of Rennlist information never ceases to amaze me. I will tell you what I have eexperienced on alignment and corner weighting.
My car, a 1997 C2 narrow body is adjusted to the following specs, Left Front fender height 25 5/8, 719 Lbs, Right Front, 25 3/4, 670 Lbs, Left rear, 25 1/2 1004 Lbs, Right Rear 25 9/16,1025 Lbs. As you add up the weights, you can see I am in need of some Slim Fast.
A good quality alignment with corner balancing done will do the job. The front spring perches have some adjustment in them, not much, but enough to corner balance the car. The rear shocks are adjustable using shims: I believe there are three sizes. If you really want to adjust the height and corner weight of the car to within a "nats eyebrow" you will be needing to upgrade to coil over suspension such as the Bilstein PSS 9 set up. It has received rave reviews on the List.
<STRONG>IF you get in the 911 and have someone measure the car's ride heights most probably everything will be equal.
All these cars exhibit this characteristic unless you have "super stiff" 900- 1500LB competition monosprings in which case a 200+ driver wouldnt depress the drivers side springs very much. I hope this helps. Have a great day.</STRONG>
As for the springs, they run 1500 lb front and 1800 lb rear - and still use the weight in the seat.
E. J.
