Inside Windshield Coating
Guys,
I bought an Escort 8500 radar detector for my car. I'm going to try and permanently mount it, but I may end up using the Escort provided "suction cup to the windshield set-up".
There is a caution in the 8500's operating manual that says "A few vehicles (including some Porsches) have windshields with a soft anti-lacerative coating on the inside surface. Use of suction cups will permanently mar this coating." This is the first time I've heard of this.
Can anyone verify if its safe to use these suction cups on the inside of the windshield? I have removed my registration and NYS inspection stickers with a razor blade and never noticed a coating on the inside of the windshield.
Any help would be appreciated.
Mike Cap
1997 C2
Arena Red
Mike Cap
1997 C2
Arena Red
Been using suction cups for over 2 years without a problem.
If it really bothers you, you can mount it on the visor. But you should be fine with using the suction cups anyways. For a slick installation, you should consider hard wiring it.
Having a cord dangle out of the cig lighter is so unprofessional.
Jeff,
Thanks. Hard wiring is the way to go, that's true. Problem is a location to mount that is out of the way and has a 'hard point' to attach to. I may look at above the rearview mirror and have a mount fabricated.
Thanks for the info on the suction cups.
Mike Cap
Mike Cap
I hardwired using the instructions from Robin's site <a href="http://www.p-car.com" target="_blank">www.p-car.com</a> and just suction cup it right above the rear view mirror and think it looks pretty good. The DIY was quite easy, just took a little time.
Good Luck.
Good Luck.
I had the same question when I bought my Escort about the windsheild, I was told by a Porsche rep that the anti lacerative stuff didn't start until 996/Boxster era.
Cheers, Robert
97 C2S
65 356 euroC
Cheers, Robert
97 C2S
65 356 euroC
Though mine isnt an Escort I have found this is be the best place to put my radar. I have had no problems with the visors and I think it looks better then putting above the rearview mirror. I also hid the wire to where it looks OEM..This is a side view but from where you sit you see no mires and no suction cups <img src="http://members.rennlist.com/96p993/wind1.jpg" alt=" - " />
Ok, who wants to build a custom rear view mirror where a V1 fit inside? I'm not talking about just the display, but the entire unit.
I think that would make for a very clean installation.
Addict & Guru
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by GratefulJED:
<strong>It does not look like the radar will work above the rear view, IMO, because it is too high to pick up the signal behind you.
</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">3 years - no problems - no reduction in front or rear sensitivity.
As Chris said, several threads have addressed this issue.
Addict & Guru
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Jeff 993TT:
<strong>I think that would make for a very clean installation.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">... and a VERY BIG installation, if the antennas are in the mirror. <img border="0" title="" alt="[Frown]" src="frown.gif" />
1. No affect on sensitivity of the rear sensor.
2. I like it above the mirror because it can barely be seen from outside the car and does not impact vision.
SKip
SKip
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Dan 96C2 St.Louis:
<strong>and a VERY BIG installation, if the antennas are in the mirror.
</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Not as big as the picture in this thread.
