seat belt VS 5 point harness
Ok, My car is on the slimfast diet and I wondered about removing my stock seat belts and using harness in daily driving situations? e
Passed On
Strapping yourself in/out of 5-point harnesses in daily drives I'm sure would become a royal PITA.
Stop worrying about a pound or two that won't make a hill of beans in your driving; leave the factory belts in.
There can be a case made that 5 point harnesses without a roll bar may indeed be less safe than factory seatbelts. In Canada, unless the belt is marked specifcally as DOT approved, it is not legal for use on the street and you can and will be ticketed. I believe that most 5 points (with some exceptions) are not DOT approved.
The factory system is engineered for many factors and takes into account the many variables found when driving a car on the street. 5 point harnesses are engineered and tested to work with the safety systems typically found in a race car (roll bar, helmets, fixed back race seats, etc).
IMO, I would use each belt system under the conditions they were engineered and tested for. Factory belts for street/normal use, 5 points for track use along with the other required/appropriate safety gear.
Cheers;
Eric
Cheers;
Eric
Legal Implications....
When you buy aftermarket belts, you sign away your life. Simson et al are not going to be there for you and your family should your seat belt(s) fail in an impact...no recourse.
However if the DOT approved Porsche seat belts should fail, you (Assuming you survive) you and your family will have legal recourse.
This speaks volumes about driving on the street with 5 point belts...not withstanding the PITA of getting in and out of the belts...I am with Ray on this one!
While all the the above statements are true about race belts not being legal on the street, what I find most interesting are the configurations that people come up with the use their 3 pt belts and harnesses. Some of the configurations I have seen for the 3 pts are really not safe. So if you think you have recourse from a accident where a 3 pt belt failed, you better make sure the install is the way the factory did it, otherwise you have zero recourse.
I personally would stick with my 6 points drilled into the floor over the 3 points any day of the week.
I've used 5-point belts on the street, ever tried getting your wallet out of your pocket in line at Starbucks? Racing belts in a street car are a royal pain, constantly getting stuck between the seats, in the backrest, under the e-brake, etc. I have put 3-point o.e. harnesses BACK IN my track car for when I drive it on the street, and switch over to the 5-points for a track event. Eric from Canada said it best...
Pete
Pete
Interestingly enough, the Schroth Profi ASM (anti submarine) harness in 4 point/ 5 point/ or 6 point are all US DOT legal. These are the ones I plan to pick up.
if you get pulled over and the cop sees you strapped in like that he will assume you've been racing...also imagine what they will write in their report if you get into an accident.
Originally Posted by riviera 93
Thanks for the input! e
In line with Eric's comment: After a little research, I found the biggest problem with the 5/6 pt. harness vs OEM belts is that if you are only using a harness bar, (much the less some DIY install sans bar) without a roll bar or cage, there is no duck factor or side to side mobility which the seemingly less stable factory belts provide. Hence, you roll, your upper body stays for the most part completely immobile, while from the shoulders up, if the roof caves, (even a little if you are tall), your neck enjoys the full force of the crush.
