993 Forum 1995-1998
Lighting up the keyhole
Old 01-21-2005, 12:17 AM
Luis A.
Luis A.'s Avatar
My '96 is 3/96 build and it does not have the light.
Old 01-21-2005, 12:57 AM
Tom 993tt
Tom 993tt's Avatar
This is why Porsche has put a light in the keyhead since the 1980"s...
Guess I am lucky, my '97 has the light above the ignition.
Old 01-21-2005, 03:45 AM
David in LA
David in LA's Avatar
You can also modify the keyhead light with an LED..."Dan 99C2 St Louis" had posted 12-18 mos ago about the mod he did.
Old 01-21-2005, 03:50 AM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
I dont have a light, so I just close my eyes..
Old 01-21-2005, 04:35 AM
husky
husky's Avatar
and enjoy the sound when the engine comes alife
Old 01-21-2005, 04:53 AM
Monique
Monique's Avatar
Originally Posted by ca993twin
my 3/95 build does not... I use the little light in the key to find the ignition. Its the "lighter weight" solution.
I grope... lighter yet
Old 01-22-2005, 04:38 PM
Herkplt1
Herkplt1's Avatar
Originally Posted by texas911
My car is a 1/95 builde (happy birthday!) and it has no light. I just changed the light bulb and battery on the key head and it works great. Could be brighter though, might do the LED mod.
I have a 12/93 build, does anyone have a date sooner than that?
Old 01-22-2005, 08:53 PM
TheOtherEric
TheOtherEric's Avatar
Speaking of the LED mod, I did this on my previous car. It was COOL, oh for about a month when it quit working. Either it shorted itself out (which is not surprising given the half-a$$ed assembly method) or the batteries just died. Either way, spending another $10-$15 on another pair of batteries is reason enough for me to avoid the LED mod on my current car. Has anyone gotten a long battery life from that mod?
Old 01-23-2005, 07:04 PM
911Jeff
911Jeff's Avatar
Default I added the ignition light to my 96.....
The mod was simple and easy. I added a 12 volt light, with a hood so that it would light the key hole with out shining in my eyes.
I drilled a small hole the size of the lamp under the insturment pod right over the ignition (the same spot that factory ignition light is located. I connected the wire to the feed for the overhead interior light so that the ignition light goes on and off with the interior light. I had to remove the left side guages to access all this, but all in all, it was an easy mod.
Quick Reply: Lighting up the keyhole
