993 Forum 1995-1998
Need help with sound system questions
Old Jan 27, 2002 | 11:42 PM
okindao's Avatar
okindao
Post Need help with sound system questions
Have a 97 C2 Triple black Cab, the car has what is called the Hi Fi sound system, ie blaukpunkpt( sp) AM /FM stereo with cassete,
i am looking to add a Cd cahnges, and also am thinking about upgrtading with a new Amp and new speakers as the current power and sound is not that great has anyone any expeirene in this area ?? does the Cd changer need to be done by Porshce dealer quoted about 800 for this, must it be in the trunk, could it be mounted in back seat floor area, as this area is only suitable for tiny dwarfs and dont want to loose the lmited front treunk area if possible . thanks in advance for any recommednations and information
dennis
c2 993 Cab
Old Jan 28, 2002 | 01:10 AM
dwe8922's Avatar
dwe8922
Post
Check back in the archives; there has been a lot of discussion on this. I upgraded my speakers to mb quart separates (6.5"), which made a huge difference in my old car. I liked them much better than the boston acoustics that came w/ my 993. Even the hi fi uses cheap nokia paper speakers. An aftermarket CD player would be as good or better than the porsche, and far cheaper.
David
Old Jan 28, 2002 | 01:40 PM
Nol, 95 993 C4's Avatar
Nol, 95 993 C4
Post
Hi Dennis,
I highly recommend you contact Rod Birch of
<a href="http://www.caraudioinnovations.com" target="_blank">www.caraudioinnovations.com</a>
He's knowledgeable, experienced with 911's and has really helped me out with good advice. He did so regardless of me being halfway round the globe, truly great service.
FWIW I've installed an Alpine CD changer in the trunk and it works fine for me. I've upgraded to Boston component speakers in both doors and rear shelve and am very happy with the sound. Next step is a multichannel amp under the passenger seat and an 8"sub, I'm awaiting delivery of the amp.
I've had the dealer install it, but there is a very limited offer of decent shops (of any kind) out here. The link above has a wealth of installation tips and pictures.
Enjoy, Nol
Old Jan 28, 2002 | 01:49 PM
mags993tt's Avatar
mags993tt
Post
The PO on my car had the cd changer installed in the trunk in such a way that it did not use up any useable space - it is basically bolted to the bottom of the carpet with a stiff plastic backing plate and it comfortably sits inside the spare wheel. Note the space saver spare does not need to be removed - there is enough space inside it.
M
Old Jan 28, 2002 | 11:48 PM
okindao's Avatar
okindao
Post
thanks for the input on the sound system , this board is very valuable in getting honest opinions from folks in the know, i appreciate everyones comments
regards
Dennis
