bump steer on the 993
Technical Guru
Originally Posted by TomF
Jason, do you have the part number for your rack? I am thinking about converting over. I show a part #964 347 011 02 in PET, but I am thinking that there is another application and part numnber from another model... cheaper than an RSA rack.
Also, are the other tie-rods solid ended as opposed to rubber on the inside as is stock on the 993? The turbo tie rod conversion I did on my 87 Cab made a HUGE difference, and they were solid ended.
TroyN, I checked out the M.O.M. website and couldn't find the GT2 tie-rods on sale. I only found the RS ones. Incidentally, will the GT2 ones work with stock uprights on a lowered car?
TomF, not sure on the fitment, you should check w/ MOM or maybe Steve Weiner. The GT2 tie rods are on the same page as the other:
http://mindovermotorsports.com/product/99334703180
RL Technical Advisor
FYI,.......
You may use the RS tie-rods with stock uprights, but GT-2 tie-rods must be used with GT-2 uprights. The angles are different.
RS tie-rods use a harder rubber in the coupler. GT-2 tie-rods have no rubber at all.
We stock and use both in various applications.
Steve, is the RS tie-rod upgrade a noticeable improvement? I really would like a feel that is more like my 87 cab was with the turbo tie-rod upgrade. Of course, this is impossible without converting over to a manual steering box, but closer is better.
Hi Tom:
Yessir, IMHO the RS tie-rods are a worthwhile upgrade to increase steering "feel" and responsiveness.
Its not quite the same as an easrly 911 with turbo tie-rods, however its a good bang-for-the-buck. The solid GT-2 tie-rods are better, but require the GT-2 uprights which is not an inexpensive proposition.
The GT-2 components are best suited for 993's that are very low and require bump steer corrections.
