PPI Results - Leakdown Interpretation Needed
Leak down results as follows:
Clyinder 1 2%
Cylinder 6 2%
Cylinder 2 2%
Cylinder 4 1%
Cylinder 3 3%
Cylinder 5 2%
DME Actual Values
Range 1 Cylinder 1-3(TRA) -0.17
Range 1 Cylinder 4-6(TRA2) -0.09
Range 2 Cylinder 1-3(FRA) 1.02
Range 2 Cylinder 4-6(FRA2) 1.01
Oxygen sensing (FR) 0.98
Oxgen sensing (FR2) 0.99
Hot film MAF 0.74 V
Ambient Pressure 930 hPa
CAN SOMEONE PLEASE TELL ME WHAT ALL OF THIS MEANS BEFORE I TALK TO THE TECHNICIAN?
Thanks!
However, Bruce Anderson, a noted 911 guru, doesn't believe leakdown tests are terribly valid, especially on the 3.6 liter 911 engines, because they only test for leakage at the top of the cylinder and because, he says, the later engines are prone to cylinder distortion. He puts much more stock in a compression test.
But with numbers like those, I don't think you have much to worry about as long as the car runs strongly. Others will chime in, I'm sure.
I don't have a clue about the DME stuff, sorry.
Vic
95 C4
Others thoughts are much appreciated!
Edward
<strong>Thanks for your quick response - Rennlisters seem to be ardent belivers in the Leak Down test - the P-Car dealer that did the test even tried to talk me out of it and suggested the given his impression of the car neither Leak Down or Compression were necessary but of course he would take my money if I insisted. He did talk me out of the compression test though suggesting that it was somewhat redundent considering the info that the Leak Down would provide.
Others thoughts are much appreciated!</strong><hr></blockquote>
FBfisher:
Everyone has an opinion on this subject and I'll just toss mine in, too...
When evaluating the condition of a used engine and trying to acertain how much life is left in the engine, (or if there are any undiscovered problems), two of the best diagnostic tests are the cold & hot compression tests and a leakdown test. Short of a teardown, these are really the only way to get a snapshot of what shape the motor is in.
IMHO, each test is complimentary with each other and one should not preclude the other. One needs to perform both as they provide different data and together, are very informative and NOT redundent.
I do not mean to suggest that these tests are perfect, but they are the easiest and most practical methods to evaluate an engine. Neither one tells you anything about valve guide wear or even if there are broken rings (from detonation), however its easier and less expensive than disassembling the engine.
Now,.....the leakdown figures you posted look good to me as this indicates good valve & ring sealing. I would be inclined to perform a hot compression test, and simply make sure that each cylinder's pressure is within 15 psi of each other.
I hope this helps answer your question and clarifies issues about which diagostic test is better than the other, or whether both should be done.
"live action" mesurement while the car is running. It hard to tell with one value. Though
the "picture" is within specs. I would say everything that I seee looks to be from a car that is running properly. As the other gent stated, your leak down is good. This is evidence
you don't have any major valve or ring issues, such as a valve that taped a piston due to a misshift or major oil starvation. Looks good from what I see.
