Will C2 front brake rotors fit rear TT calipers?
Hi,
I have just purchased big reds for my C2 with standard calipers. I have a new set of standard front brake discs and given that the front standard pads fit the rear TT calipers, will the front rotors also do for the rear with TT big red calipers or do i really need to buy new rear TT rotors?
TIA
John
TIA
John
The 993 front caliper is designed for a 32mm thick rotor, the 993tt is only 28mm. At full pad thickness this is doable but as the pad wears it becomes increasingly prone to hyperextension.
