With RS Wing, where does the high mount brake light go?
I am considering adding the RS rear wing to my 95 993 with the early model basket handle rear spoiler. The RS wing (MASHAW) doesn't appear to have a brake light. What are my options for meeting the DOT requirements. Thanks.
You could not mount one like me and well, probably get done some day under visual inspection, or, get the third brake light in the back window available on the '96 onwards? Are you familiar with it? It's called an aero piece I believe? Sits at the top of the rear window.
Dylan.
Dylan.
adding the oem high mount brake light to your rear glass as found on the 96 and later models. Gert sells a retro kit (oem) that comes with all you need to install on your early MY95....
