Pss9 Issue
Pss9 Issue
Completed the DIY project over a year ago with the install of the Pss9's as well as the RS sway bars. Really have enjoyed the transformation, however about a month ago the front end has developed a strange noise. The noise appears when the steering wheel is turned in either direction with the car is not moving. It sounds as if the front springs are loose or moving. The car sits at RS specs the alignment is also set for RS specs and drives great. Before I open it up thought I would check and see if anyone has experienced this.
Alan
Alan
The coil springs sound like they are binding. Did you install the blue plastic shim between the helper spring and the spring seat on the front strut?? Are you running monoballs by chance as I have seen that if these bind, they will also cause the same type of spring noise..
