Rear Wheel Bearing R&R - what tools do I need?
My left rear wheel bearing is in need of replacement, and I plan on doing it myself. From the previous posts here it doesn't sound too difficult. I know I need a BF torque wrench capable of 339 ft-lbs, as well as a 32mm socket, and a breaker bar to get it undone. What else is needed?
I was looking at the Baum Tools website, and they list 13 different tools for the rear suspension, of which about 6 look like they may be involved in the wheel bearing R&R process (click here for link to the site)
So which ones do I need to do this job? From previous posts it seems that only one tool is really needed, but which one?
And is there any other tool that is useful? I'd hate to get started on the R&R and find that I'm missing some specialty widget needed to complete the job.
TIA for any help.
TIA for any help.
Look at Engine Builders Supply. They have what you need. Not on their website, but just ask them. You just need a single tool (it comes with lots of bits) for R&Ring the wheel bearing. Cost is about $130. BE ready to take the stub axle to a mahine shop to get the front race of the wheel bearing off (unless you have a REALLY good 2 jaw puller). This gets destroyed in the removal process. Be careful when reinstalling so the the stub axle does on push out the back side of the wheel bearing.
Thanks for the suggestion... the tool should be here next week.
Also, does anyone have a good DIY procedure (with pics) for this? I'd like to use a step-by-step procedure that way if I screw up it will be due to stupidity and not ignorance.
TIA
At a DE this weekend, I noticed a 1/rev sound that grew progressively worse. With the car off, you could push it fwd/backward and hear the bearing hitting a bad spot. A few others with better ears could tell the sound was coming from the hub and not the CV.
When the sound first started I was hoping it was something else, like something between the rotor and shield... alas, that wasn't the case.
Jason - Yes and no. It can help in the removal of the bearing, but the EBS tool also helps the installation of the bearing and the stub axle into the bearing WITHOUT allowing the axle to push out the inside bearing race. Trust me, there is nothing more frustrating than going through all of this and on the last step you destroy the bearing and you have to start all over again....
Jeff - You may also notice that when you jack the car up you can twist the wheel and you will have some play... If things get real bad, you have to replace the stub axle (about $300) due to wear......
Jeff,
Do you have an air compressor? if so use a impact wrench. If not I don't see why a breaker bar wouldn't work as long as you use an impact socket.
I do have an impact wrench and compressor, but I don't think the wrench has enough cajones to get that nut off.
If I can't get it done with the breaker bar, I guess I'll splurge for a better gun.
