removing front seat belts
Darth Cup
I can't quite figure out how to remove the front seat belts. Trouble is that the male insert into the seat belt buckle won't allow the belt to be removed through belt guide bolted to the b-pillar.
Thanks for any suggestions.
The process is easy.. here are the instructions.
<a href="http://www.johnfelker.com/belts/beltinstall.html" target="_blank">http://www.johnfelker.com/belts/beltinstall.html</a>
Darth Cup
John,
Looking at your link I finally figured out that the belt can slide out from behind the plastic clip that lines the opening in the interior trim panel.
Thank you!!!
Thank you!!!
