Picture Of Humpty Dumpty's Almost Completed Engine
Engine features include:
1. Blueprinted And Dynamometer Tested
2. America GS Engine Management System Programmed For Use With America GS Tiptronic® Transmission
3. America GS High Flow Hot Wire Induction System
4. Reduced Weight Cam Deck
5. America GS Drilled Camshafts
6. Reduced Weight Adjustable Rocker Arms
7. America GS Cylinder Heads With Copper/Beryllium Valve Seats
8. America GS Cylinders
9. America GS Lightweight Pistons
10. America GS Metal Matrix Composite Wrist Pins
11. America GS Titanium Connecting Rods
12. America GS Aluminum Gears
13. America GS Aluminum Sprockets
14. America GS Titanium Intake Valves
15. America GS Titanium Exhaust Valves
16. Uprated High Pressure Fuel Pump
17. Uprated Fuel Rail
18. Adjustable Fuel Pressure Regulator
19. America GS Engine Oil System
a. America GS Carbon Fiber/Titanium/Aluminum Engine Oil Tank With Uprated Anti-Aeration Cone
b. Increased Pressure And Scavenge Engine Oil Pump
c. America GS Aluminum High Efficiency Triple Engine Oil Cooler System
d. America GS Aluminum Engine Oil Cooler Distribution Manifold
e. America GS Aluminum Engine Oil Lines With Machined Aluminum Fittings
f. America GS Machined Aluminum Engine Oil Line Fitting
g. America GS Machined Aluminum Oil Filter Console Fittings
h. America GS Machined Aluminum Thermostat Fittings
i. Goodridge G-Line XF Engine Oil Hoses With Goodridge Machined Aluminum AN Fittings
20. Uprated Gaskets
21. America GS Increased Flow Air Filter Box With Induction Snorkel And Increased Air Flow Lid
22. BMC America GS Increased Flow Air Filter
23. Plastic Valve Covers
24. Crankshaft, Flywheel, Pressure Plate, Connecting Rods, Connecting Rod Ends And Pistons Balanced
25. Engine Cleaned, Ported And Polished
26. Engine Case Windage Adjusted
27. Engine Case Dovetailed
28. Goodridge G-Line XF Fuel Hoses With Goodridge Machined Aluminum AN Fittings
29. America GS Lightweight Alternator With Titanium Shaft
30. America GS Titanium Pulleys
31. America GS Titanium Cam Deck Fasteners
32. America GS Titanium Chain Housing Covers Fasteners
33. America GS Titanium Fasteners
34. America GS Titanium Washers
35. America GS Titanium Engine Casing Studs
36. America GS Titanium Engine Exhaust Studs
37. America GS Titanium Engine Support Mounting Studs
38. Silver Plated Jet Nuts
39. America GS Carbon Fiber/Aluminum Engine Support/Engine Shroud/Air Conditioning Compressor Mounting Platform
40. America GS Titanium Air Conditioning Compressor Support Bracket And Fasteners
41. America GS Carbon Fiber/Titanium Engine Mounting
42. America GS Carbon Fiber/Titanium Solid Engine Mounts
43. America GS Titanium Engine Mounting Fasteners
44. Castrol RS Synthetic 10W60 Racing Engine Oil
20. Uprated Gaskets
First, living in a metropolitan area, I like the Tiptronic. And, second, the specs:
1. Tiptronic® Transmission – Blueprinted, Polished, Reinforced And Dynamometer Tested
2. High Performance Software For Tiptronic® Transmission Including:
a. Specially Programmed For Use With 3.8 Liter America GS Engine
b. Permits Driver To Hold Transmission In Gear In "Tip" Mode – Transmission Will Not Override Driver
c. Higher Performance In Automatic Mode
d. Transmission "Learning" More Rapid In Automatic Mode
3. America GS Carbon Fiber Side Transmission Housing
4. America GS Wire Electro-Discharge Machined 300M Transmission Output Flanges
5. America GS Lightweight Flywheel
6. America GS Titanium Transmission Linkage Brackets
7. America GS Aluminum High Efficiency, Lightweight Transmission Oil Cooler
8. Goodridge G-Line XF –8 Hoses With Goodridge Machined Aluminum AN Fittings From Transmission To Transmission Oil Cooler
9. Parker Hannifin –8 Aluminum Quick Disconnects Between Transmission And Transmission Oil Cooler
10. America GS Delrin® Transmission Mount
11. America GS Carbon Fiber Transmission Fluid Pan With Titanium Drainage Plug And Titanium Banjo Fluid Fitting
12. America GS Titanium Transmission Fluid Pan Fasteners
13. America GS Titanium Transmission Fasteners
14. America GS Titanium Transmission Mount Fasteners
Oh I almost forgot. I looked around for the Parker quick disconnects about a month ago but couldn't find a source. Could you point me in the right direction to find these.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Looks great Robert (as usual)! Not sure what to say because I am breathless, truly.
Next step is a carbon 'tub' to bolt all this stuff to. We can do that for you
