993 Forum 1995-1998
993 MODIFICATIONS
Old Aug 31, 2004 | 11:59 AM
sbturbo@aol.com's Avatar
sbturbo@aol.com
Default 993 MODIFICATIONS
Need some help....just purchased a 1995 911 coupe. Looking for suggestions for street and DE events with the following:
- suspension
- exhaust
- Interested in 18" ---wheelsize and tire size
- air box systems
- brakes...leave stock
Steve
Old Aug 31, 2004 | 12:22 PM
nile13's Avatar
nile13
Search and yee shall find.... a lot.
Old Aug 31, 2004 | 12:42 PM
FlyYellow's Avatar
FlyYellow
contact viperbob and get pss-9 and adjustable sway bars. then you are ready for DE. forget airbox. 18" technology wheels are a nice add...
Old Aug 31, 2004 | 12:50 PM
akolodesh's Avatar
akolodesh
Just my opinion, but here goes:
Suspension: anything from Bilsteins w/ M030 or H&R springs to PSS9 depending on your budget.
exhaust: Robins RSRs to Fabspeed Maxflows depending on your desire for sound
Wheels: wow! many good options. Depends on whether you want forged, multi-piece, etc... Probably 8" in front and 10" in back will work well. Tires should be somewhere in the 225/40 front 285/30 range. Quality wheels can come form: Kinesis, Fikses, Forgeline, HRE, etc...
Airbox system: cut out the side or drill some holes (save your money on other mods)
Old Aug 31, 2004 | 12:58 PM
Flying Finn's Avatar
Flying Finn
King of Cool
- suspension: PSS-9 or Motons, RS sway bars and better also get monoballs while at it.
- exhaust: Fabspeed Supercups (very loud) or RSR's.
- Interested in 18" ---wheelsize and tire size: 18"x8.5 (235 tyre) & 18x10.5 (275 tyre)
- air box systems: Drill the airbox (or buy used K&N cone filter from me...)
- brakes...leave stock: You can leave stock but get track pads and maybe some cooling.
Old Aug 31, 2004 | 01:11 PM
Rick Lee's Avatar
Rick Lee
I've done all of these.
- Bilstein HD's with H&R springs
- FabSpeed MaxFlows
- 996 5-spokes with 285/30/18's on the rear
- drilled my air box
- installed Big Reds
I've also installed a C2S split grille and plan a LWF/RS kit soon. Then I'm really done!
Old Aug 31, 2004 | 01:14 PM
kdurg's Avatar
kdurg
- FabSpeed MaxFlows
Done ?? Yah right........who you kiddin' ??
Old Aug 31, 2004 | 03:45 PM
akolodesh's Avatar
akolodesh
Hey Flying Finn,
Is the reason for 235 front 275 rear (as apposed to 225/285) to decrease oversteer (?)
thanks
Old Aug 31, 2004 | 03:48 PM
FlyYellow's Avatar
FlyYellow
Alex,
yes, but it raises your ride height....
Old Aug 31, 2004 | 03:52 PM
akolodesh's Avatar
akolodesh
Default really?
Originally Posted by Boris Teksler
Alex,
really?
Old Aug 31, 2004 | 04:05 PM
FlyYellow's Avatar
FlyYellow
yes really.
here is a table for your benefit..
width profile rim size ride height (inches)
225 40 18 25.08661417
235 40 18 25.4015748
275 35 18 25.57874016
285 30 18 24.73228346
Old Sep 1, 2004 | 01:00 AM
FlyYellow's Avatar
FlyYellow
as a sidenote i run two different configs:
autox: to increase oversteer i run 245 (front) and 275 (rear)
track: to increase understeer i run 225 (front) and 285 (rear)
i feel this to be safer for a track setup, but in the tight corners of autox my setup really works! I just wish they made the 275 in a 30 series because i don't like the taller gearing (reduces torque).
Cheers,
Boris
Old Sep 1, 2004 | 01:13 AM
Flying Finn
King of Cool
Originally Posted by akolodesh
Hey Flying Finn,
thanks
As others have pointed out, it's to increase oversteer.
Obviously just a suggestion and based on my preferences. I rather have oversteer than understeer, undrsteer is safer and easier to handle so many folks actually prefer (little) understeer, but that's for you to decide what suits you best.
Old Sep 1, 2004 | 01:41 AM
993RS's Avatar
993RS
You guys should really not be encouraging newcomers to indulge in mods...
Old Sep 1, 2004 | 11:33 AM
akolodesh's Avatar
akolodesh
thanks Kim, Boris and Flying Finn - good to understand the relationship between the widths of front and rear tires
