Weight chart for C2 vs C2S vs C4S vs Targa?
The 3064 lbs listed for the C2 in the US literature should include standard equipment, so it should include AC and a sunroof.
Does anyone know what fuel level is used for the so-called "curb" weight?
Does anyone know how much weight the sunroof adds? My car is a sunroof-delete car.
my car currently weighs in at 2948 with 1/4 tank of gas... i'm constantly looking for removing weight. today i removed 1/4lb of weight of my car.
cheers,
boris
cheers,
boris
King of Cool
Todd,
That 3064 lbs does not include sunroof or a/c.
I'm not sure about "curb" weight but I'd assume that means the same as DIM weight, which is tank full of gas (plus all other fluids).
Addicted Specialist
Originally Posted by CP
Interesting. My 95 C2 (RUF BTR) weights in at 2,994# with full tank of gas when it was on the scales during corner balancing. If stock was 3,064#, then it was not a huge improvement. Well, 70# is still 70#s.
CP
CP
A more reasonable comparison would be your full wet weight against that of a TT. Now how's THAT for savings!
Edward
Funny enough, my racing 993 when she was stock with rollbar and the heavy RSCS tail never made the 3064 weight! I had to add weight to make it through... By this I was always under the impression that the 95 C2 was lighter than the posted 3064 weight...
My n/b '95 Coupe on corner balance scales weighed 3260 w/ a full tank and 200+ lb driver.
after a major diet on the same scales same condition 2945
since then a DAs rollbar has been added and a much lighter tail subtrated a bit.
As another data point, my '97 C2S, when stock and with a full tank of gas, came in at 3115lbs on our scales. With driver, it was 3400 (on a light day!).
