993 Forum 1995-1998
PSS9 Problem
Old Aug 25, 2004 | 09:30 PM
Jim in St.Louis's Avatar
Jim in St.Louis
Question PSS9 Problem
My PSS9 coil overs have been on my 993 for a couple of years and they have started to rattle. The front top portion of the coil overs are loose and rattle and the springs sometime make a boing type noise. Any suggestions?
Jim
Old Aug 25, 2004 | 09:52 PM
TrackJunke's Avatar
TrackJunke
Try checking the tightness of the topnut.
Old Aug 25, 2004 | 09:54 PM
viperbob's Avatar
viperbob
Former Vendor
Torrington bearings.. 60mm .
Old Aug 25, 2004 | 09:58 PM
Jim in St.Louis
What is a 60mm Torsen?
Jim
Old Aug 25, 2004 | 10:08 PM
viperbob's Avatar
viperbob
Former Vendor
This is a thin roller bearing that is sandwiched between 2 steel shim. It sits under the front spring (which is 60mm in a PSS9 set) then and allows smooth movement of the spring in the shock when the wheel is turned without the boing effect... This is common in older sets where some level of corrosion has come in, and in more race applications with very high spring rates.
Old Aug 25, 2004 | 11:16 PM
BradB's Avatar
BradB
Jim,
I am not sure what the cure might be but am willing to take a look with you. Maybe we can confirm the previous diagnosis. I have a lift and we can easily toss the car up and take a look. I also have PSS9's on my C4S. If you would like to get together let me know. PM me.
Brad, St. Louis
Old Aug 25, 2004 | 11:28 PM
Jim in St.Louis
Brad,
I don't get out much, so what is a "PM you?"
Jim
Old Aug 25, 2004 | 11:52 PM
STLPCA's Avatar
STLPCA
Addict & Guru
Originally Posted by Jim in St.Louis
Brad,
Jim
Brad
Be gentle - Jim's an old guy (like me)
Jim
Click here to send a PM (Private Message) to Brad.
Old Aug 26, 2004 | 01:10 AM
viperbob's Avatar
viperbob
Former Vendor
You can see the bearing installed at the bottom of the spring on the previous link.
