Picture Needed Urgently
Haiku Grasshoppa
Can I Drove Your Car?
Hey Robert,
I saw this photo the other day, and I thought of you.
<img src="http://www.falconcars.com/Timeline/088_crash_test_attenuator.JPG" alt=" - " />
I believe the connection relates to him beating his head on a wall while it's in what appears to be a carbon fiber bucket . . . you of course being the connoisseur of CF parts.
By the way, any recent pieces?
carbon fiber front hoods
carbon fiber front fenders
carbon fiber rear fenders
carbon fiber roofs
carbon fiber floor pans
carbon fiber doors
carbon fiber exterior mirrors
carbon fiber engine compartment lids
carbon fiber front spoilers/air deflectors
carbon fiber adjustable rear wings
carbon fiber bumper mounted air ducts
carbon fiber fender mounted cooling ducts
carbon fiber upright mounted cooling ducts
carbon fiber CV joint/tripod cooling ducts
carbon fiber engine oil cooler cooling ducts
carbon fiber transmission oil cooler cooling ducts
carbon fiber radiator cooling ducts
carbon fiber front brake cooling ducts
carbon fiber rear brake cooling ducts
carbon fiber engine oil cooler mountings
carbon fiber transmission oil cooler mountings
carbon fiber radiator mountings
carbon fiber air conditioning condenser mountings
carbon fiber air conditioning compressor mounting brackets
carbon fiber central tunnel covers
carbon fiber high pressure fuel pump mounting brackets
carbon fiber lift pump mounting brackets
carbon fiber fuel/oil filter mounting brackets
carbon fiber high pressure fuel pump area covers
carbon fiber fire extinguishers with carbon fiber brackets
carbon fiber front and rear bumper covers
carbon fiber dashboards
carbon fiber defogger vents
carbon fiber center consoles
carbon fiber undertrays
carbon fiber brake system covers
carbon fiber fuse and relay boxes and boxes covers
carbon fiber battery mounting straps
carbon fiber exhaust cooling systems
carbon fiber engine air boxes
carbon fiber engine oil tanks
carbon fiber valve covers
carbon fiber induction systems
carbon fiber engine encasings (sheet metal replacements)
carbon fiber fans
carbon fiber wire managers
carbon fiber/titanium shrouds
carbon fiber/titanium motor brackets
carbon fiber/titanium motor mounts
carbon fiber/Kevlar® fuel cells
carbon fiber fuel cell mounting straps
carbon fiber/Kevlar® fuel cell access plates
carbon fiber fuel cell nut rings
carbon fiber fuel pump mounting brackets
carbon fiber fuel filter mounting brackets
carbon fiber steering columns
carbon fiber steering rack housings
carbon fiber wishbones
carbon fiber "A" arms
carbon fiber control arms
carbon fiber multi link suspensions
carbon fiber suspension mounting members and subframes
carbon fiber struts with adjustable dampers
carbon fiber/titanium pushrods
carbon fiber adjustable anti roll bars
carbon fiber shock tower braces
carbon fiber transmission housings
carbon fiber bell housings
carbon fiber transmission fluid tanks
carbon fiber gear shifts ***** and release buttons
carbon fiber hand brake levers
carbon fiber gas, brake, clutch and rest pedals
carbon fiber roofs
carbon fiber doors
carbon fiber fans
Lifetime Rennlist Member
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Robert Linton:
<strong>I do not see the connection. Perhaps you could explain.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Ray Charles could see that connection.
<strong>Perhaps it should be sent to Mr. Charles!</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">I sent the picture to him - he laughed and said "That reminds me of Robert. If you talk to him, ask him if he has finished my Carbon Fiber Piano yet."
The jokes being over, does anyone have pictures of the 993 exhaust system? Thanks.
By the way, in direct response to the question about new carbon fiber parts that would lend themselves to Porsche racing and not be so expensive as to be only practical for a LeMans Prototype:
carbon fiber engine oil tanks with improved anti aeration (for racing, preferably moved forward for better weight distribution)
carbon fiber/aluminum struts
<strong>Carbon fiber door sills are easy.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">hmmm...perhaps a group buy is in order?!?
David:
Frankly, other than for the look, this is a waste of money -- carbon fiber should be used primarily for applications such as racing where its qualities (e.g., stiffness and weight) justify the cost. Further, if you were to use it for door sills, given that it can splinter, I would blend it with Kevlar® so as to add tear resistance.
