993 Forum 1995-1998
Good tool for plug changes?
Old Nov 9, 2001 | 08:50 PM
Robert Henriksen's Avatar
Robert Henriksen
Post Good tool for plug changes?
Got some periodic Snap-On marketing, and thought this looked interesting. Anyone w. 993 spark-plug-changing experience think this might save any time or skin?
http://buy.snapon.com/catalog/search...e=snapon-store
Old Nov 9, 2001 | 10:15 PM
Robin 993DX's Avatar
Robin 993DX
Lifetime Member
Post
Robert,
Those wouldn't do you any good, the 993 plugs are burried deep within, so you will need the universal after you add a 4" extension to the spark plug socket. Anything before that wouldn't do anything.
Old Nov 9, 2001 | 11:27 PM
Robert Henriksen
Post
Nothing like the voice of experience, thanks!
Old Nov 10, 2001 | 01:40 AM
dwe8922's Avatar
dwe8922
Post
Snap on does make a spark plug wire puller that I found useful enough to buy. Those boots can be hard to pull of with your fingers, and I know a couple people who have damaged boots that way. Definately not a necessity, but I was glad to have it for 3 boots I couldn't easily pull with my fingers.
D
Old Nov 10, 2001 | 02:42 AM
Ray Calvo's Avatar
Ray Calvo
Passed On
Angry
After the major aggravation, 2 weekend effort to change my spark plugs at 30K miles, I made up the attached tool (still haven't used it tho). Took one of those long handle spark plug tools that have a T-handle at the end to start with. I then cut off the handle end, ground the end on the piece attached to the spark plug socket into a hex end. I then took a 7mm 3/8" drive Craftsman Allen head socket, took the 7mm Allen drive piece out (it's only held in place by a little screw in the side), then attached this to the end of the above extension.
Total length is about 6"; hopefully this will do as well as the Snap-On socket and 4" extension described in the shop manual.
Look at the quality of these T-handle spark plug tools; this one seemed of decent quality and was made by Great Neck. 5/8" spark plug drive; part no. US58.
One last thing: the universal joint is rather "floppy". To give it some stiffness, I wrapped it in electrical tape; stripped this off to better show you the tool.
Old Nov 10, 2001 | 09:06 AM
Jeff96-993's Avatar
Jeff96-993
Post
Ray,
"Pat Pend" should appear somewhere on that tool. I'm off to the local tool supply store to see if I can duplicate your creation.
