993 Forum 1995-1998
Tyre pressure on slicks
Old 08-01-2002 | 05:21 PM
Steve in the UK's Avatar
Steve in the UK
Post Tyre pressure on slicks
Any of you racers help me out. I recently bought a 968 ClubSport that came with a spare set of wheels fitted with new Pirelli PZero slicks. I'm planning on using them next week at Brands Hatch and wondered whether tyre pressures on slicks should be the same as normal road tyres. Any advice would be much appreciated.
<img src="graemlins/icon107.gif" border="0" alt="[icon107]" />
Old 08-01-2002 | 05:39 PM
Chris in Detroit's Avatar
Chris in Detroit
Post
I would go somewhat lower than street - I was running a 993 with P-Zero Cs and ran COLD PRESSURES of 28psi front and 30psi rear - this seemed to work out well.
For a 968 you might want to start out at 30psi all round COLD and aim for 42 psi or so HOT
Old 08-01-2002 | 05:40 PM
Chris in Detroit
Post
Ooooooooops mis-read your post - my advice was for P-Zero Cs, not P-Zero slicks (if they are different), although the advice on low 40s psi HOT is pretty universal.
Old 08-01-2002 | 07:33 PM
DJ's Avatar
DJ
Haiku Grasshoppa
Can I Drove Your Car?
Post
[quote]Originally posted by Chris in Detroit:
<strong>Ooooooooops mis-read your post - my advice was for P-Zero Cs, not P-Zero slicks (if they are different), although the advice on low 40s psi HOT is pretty universal.</strong><hr></blockquote>
...pretty universal except for some R-compound tires, and especially not for slicks. I can't remember the exact numbers, but I think the recommended cold pressures are 25 front / 23 rear, and hot are around 32.
Old 08-01-2002 | 11:50 PM
Chris in Detroit
Post
DJ - I did some more digging - seems that specs vary very widely e.g.
<a href="http://www.tirerack.com/tires/hoosier/hoosier_tips.htm" target="_blank">Tire Rack - Hoosiers</a> recommends low 40s hot unless your car is very light
<a href="http://www.tirerack.com/tires/bfg/bf_careandfeeding_gforce.htm" target="_blank">Tire Rack - BFG-T/A R1s</a> recommends 40-45psi hot
<a href="http://www.tirerack.com/tires/kumho/ku_v700_care.htm" target="_blank">Tire Rack - Kumho V700</a> recommends 35-40psi hot
BUT, then I found
<a href="http://www.visionmotorsports.com/Tires.html" target="_blank">Pirelli Tech Specs</a> which as you said, recommend hot around 32psi
SO, very much depends which slick tire you have ......
Old 08-02-2002 | 02:22 AM
DJ's Avatar
DJ
Haiku Grasshoppa
Post
<strong>
SO, very much depends which slick tire you have ......</strong><hr></blockquote>
All good info, Chris, but the pressure specs on Dwain's site are most likely for 944's, as Vision is mostly a 944 race shop. Still, the numbers would be in the same ball park.
Also, in this group of tires, only the Pirelli is considered a slick. The others are DOT-rated R-compound tires. Big difference.... about 4 seconds a lap.
Old 08-03-2002 | 05:52 AM
Steve in the UK
Post
Chris and DJ, many thanks for your assistance on this. My tyres are indeed Pirelli slicks and thanks to your help I now know what pressures to put in. I had a feeling that they should be lower than normal so I am glad I checked first.
Old 08-03-2002 | 10:34 AM
Hank Cohn's Avatar
Hank Cohn
Post
Steve:
DJ’s recommendation is spot on. I have run numerous sets of Pirelli slicks on a GT3-Cup car and our fastest lap times were achieved at 32-33 PSI hot. If you are using air rather than nitrogen then you might want to start with a lower initial pressure like 25 PSI or even 24 PSI if it is hot day. It takes the Pirelli slicks at least two laps to generate enough heat to really stick, so be careful.
Hank
Old 08-04-2002 | 06:02 PM
Steve in the UK
Post
Hank
Thanks for the advice on warm up times. All I need now is for the sun to shine.
Regards
Old 08-04-2002 | 07:58 PM
Jean-Marc's Avatar
Jean-Marc
Post
[quote]Originally posted by Hank Cohn:
<strong>Steve:
Hank</strong><hr></blockquote>
Someone, PLEASE ask Hank how he knows about the 2 laps rule for Pirellis !
Quick Reply: Tyre pressure on slicks
