993 Forum 1995-1998
condensation in tail
Old Nov 5, 2001 | 09:42 AM
tom97c4s's Avatar
tom97c4s
Post condensation in tail
I have a 97 c4s and I have just noticed a lot on condensation inside the whole tail section. I removed the reflective tail section and was able to dry it out. But how do I prevent this from happening? Does any one know the cause?
Old Nov 5, 2001 | 12:18 PM
GeoC2cab's Avatar
GeoC2cab
Post
High,
Don't really know a cause, but a possible cure maybe; how about putting the spoiler up manually after driving? (I do it and never found condensation)
Old Nov 5, 2001 | 05:32 PM
tom97c4s's Avatar
tom97c4s
Post
Thanks for the response. Has anyone else had this problem before? Or is an isolated proplem that I am experiencing?
Thanks!
Tom
Old Nov 5, 2001 | 05:49 PM
STLPCA's Avatar
STLPCA
Addict & Guru
Post
Tom
Don't believe it's a common problem. FWIW, here's what one Rennlister (who never drives in rain!!!!) posted:
Posted By: Allen - '97 993 coupe
Date: posted 4/25/01 at 2:00 p.m.
The previous owner of my car had the entire rear lense replaced because condensation continued to collect in the area you mention. The problem occurred in the replaced lense as well. If you have discolored molding inside the lense, you will have to remove the assembly, then the bulb to gain access to the inside area, the somehow clean out the mold.
Since I was aware of the problem when I bought the car (it had no molding in it at the time), I have done (2) things: 1 - I removed the entire taillight assembly and used silicon to seal any "gapped" areas when water might enter and cause mold. 2 - I have just tried to be careful when washing the car, trying to minimize the amount of water flowing over that portion of the lense. This has worked for me as I have no condensation problem at all...however, I also never drive the car in the rain either.
