Mystery plastic tube in the trunk
Lifetime Member
Lifetime Member
While in the process of installing a battery tender in the new car(1997 Arena Red C2S), I found a loose clear plastic tube attached to the left inside fender wall. The forward end is hanging loose near the battery. I can't see where it should terminate. Not a big deal, but I would like it right. TIA.
Lifetime Member
Lifetime Member
It is the ventillation tube for the battery. As the battery being charged and discharged it produces hydragen, and enough of it and the right spark could cause an explosion if not vented properly.
If you bought the proper battery it should have a connector near the top for you hook that tube up to it.
I believe that it is a vent for the battery. On my '97 it connects to the cap on top of the battery. It is supposed to vent the fumes from the battery outside, instead of the in the sealed trunk.
Sounds like it is the tube that is the vent for the battery. The end that is not connected should be pushed into the battery vent connection. Most batteries have a venting port. I know Porsche and Die Hard International, Interstate batteries have a connector for this venting tube. It is important to attached the tube to release acid gasses outside, and not keep inside battery trunk area.
In addition to the vent tube info given above, I've actually disconnected the vent tube going to the side fender, because the gases started corroding that section of fender
What I did was run the vent tube from the battery, down to a factory hole underneath the spare tire. Here the battery gases, fluid can safely exit without ruining my fender wall or corroding the area near the battery.
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Lifetime Member
Lifetime Member
Thanks, folks. There IS a vent tube on the battery, even if the label says "Econo Power"! I'm not used to fancy stuff like vent tubes for the battery. I'm sure I will find lotsa more neat stuff on this car as I continue exploring. Cool.
