993 Forum 1995-1998
Is the 3.8L RS conversion worth it?
Old 06-03-2002, 11:39 PM
Eric in Chicago
Eric in Chicago's Avatar
Post
Martin, step away from the book (and send me a copy)
Old 06-03-2002, 11:49 PM
SundayDriver
Lifetime Rennlist Member
SundayDriver's Avatar
Post
[quote]Originally posted by ZCAT3:
<strong>Kim - we are getting a bit OT here - but... the 1 day event appears to focus more on the orientation stuff with the bulk of the track time on the second day. We have a chance to do a full day at Willow Springs in July for $450, so that is what we are balancing it against.
By the way - it took one turn at the wheel of a TT to get me hooked (same for Michele).</strong><hr></blockquote>
I hope you have an aux oil cooler. Willow in July is tough and you may not be able to run for long. Also, you can run most Firdays at Willow as a test day. $150 for one car and one driver, as I recall. First time is another $75? for an annual test card.
Old 06-04-2002, 01:19 AM
993RS
993RS's Avatar
Post
Unfortunately, when I upgraded to the 3.8L kit, I also at the same time added Varioram. I really felt a difference, also because of the much better torque curve. But a lot of the improvement certainly came from the Varioram enhancement. Guess if you have a Varioram engine, the improvement will not be quite that noticeable, as Hank says...
Afterwards, I then did the RoW gearing. Subjectively, this was a similar jump in performance as the prior, much more expensive modification.
BTW: In Paul Frere's excellent book, he mentions the 911 Cup 3.8 RSR used in the Japanese GT3 class. It developed 340 hp at 7000 rpm with a 7400 redline. The higher hp, compared to the European Cup car, came from a slightly different camshaft, but essentially from the absence of the exhaust catalyser, he says.
Old 06-04-2002, 02:52 AM
ZCAT3
ZCAT3's Avatar
Post
Mark - we do have a Turbo S aux oil cooler. Good point about Willow Springs in July, though. We were there in April and it was perhaps 80 degrees at the warmest time of the day. The oil temp held at the first notch or below all day. I prefer not to do open track runs as I value the more controlled environment of a DE.
Old 06-04-2002, 05:32 AM
JDW
JDW's Avatar
Post
Bill, I think I'm 170 lbs over the limit. The gearbox hurt me too. I think you would go through three to my one. It's true that doing everything at once and dynoing it would be the right way to go. My car has add ons thrown together. The exhaust and headers probably hurt HP but the weight savings make up for it. Never dynoed the car to see. YES I am ready to lie cheat and steal for that upgrade.
Old 06-04-2002, 07:16 AM
993RS
993RS's Avatar
Post
Have any of you guys changed the intake system?
Old 06-04-2002, 12:17 PM
Bill - Chicago
Bill - Chicago's Avatar
Post
Jerry - when you say 3 to 1 are you taking about the back straight. I was getting into 5th there and existing the keyhole in 2nd. This was the same as I did in my 996. You could not be in only one gear there. At Sebring Greg and I were shifting at about the same place.
Old 06-04-2002, 12:20 PM
Bill - Chicago
Post
Jerry - Also if you have not done the RS gears. I would definitly do this before the engine, and delete the extra 170 pounds would be the first thing I would do. The engine upgrade helps but not that much.
Old 06-04-2002, 03:17 PM
Greg Fishman
Greg Fishman's Avatar
Post
[quote]Originally posted by Bill - Chicago:
<strong>Jerry - Also if you have not done the RS gears. I would definitly do this before the engine, and delete the extra 170 pounds would be the first thing I would do. The engine upgrade helps but not that much.</strong><hr></blockquote>
Bill,
You are not helping. I have enough trouble staying near Jerry now. I think he needs to add weight.
I do agree the gears and weight are probably a better place to spend the $$ first.
Jerry was so fast he was coming out of the keyhole in 4th gear, so he only needed to shift once on the back straight.
Did your shop install the Woodruff (sp?) keys or pins for the camshafts? There have been a couple posts on the subject and Steve W. has suggest doing that.
Greg
Old 06-04-2002, 04:03 PM
JDW
JDW's Avatar
Post
Front straight. I exit carousel in third, carry 4th from front stretch into keyhole, exit keyhole third. Does anyone have an aluminum hood for sale?
Old 06-04-2002, 04:05 PM
Hank Cohn
Hank Cohn's Avatar
Post
JDW:
I have one, but the price is $2000.00
Hank
Old 06-04-2002, 04:08 PM
Hank Cohn
Hank Cohn's Avatar
Post
JDW:
I have RSCS doors too with crank up windows and manual locks. $1500 for the pair.
Hank
Old 06-04-2002, 04:40 PM
Greg Fishman
Post
Jerry,
I think Larry S. has some aluminum doors ask Brian next time you talk to him.
Hank,
How much weight savings do you get with the aluminum doors, and hood?
Why don't you use them on your RS conversion?
Greg
Old 06-04-2002, 05:49 PM
Shark01
Shark01's Avatar
Post
<strong>Shark - what do you mean by "open air experience" - a cab? I sold our Cab to buy the TT. It all depends on what you are looking for. The post here was about more power in a 993. If you have never driven a 993TT I suggest you give it a try if the opportunity ever arises. It is truly a seamless integration of power into the 993 platform. The TT is everything the 993 is, only faster.</strong><hr></blockquote>
If it doesn't offer at least a targa top, I'm not interested I feel the same way about automatic transmissions, just isn't a sportscar that way. I understand what the post is about, that's why I recommended a supercharger
Old 06-04-2002, 06:16 PM
Hank Cohn
Hank Cohn's Avatar
Post
Greg:
I weighed them a while back and posted the results, but I don't remember the numbers now. I think the aluminum hood weighs 17 lbs and the doors weighed about 55 lbs if memory serves. I don't think RS doors are aluminum, but I may be wrong. As far as I can recall, there are no aluminum doors for the 993 series of cars.
Hank
Quick Reply: Is the 3.8L RS conversion worth it?
