993 Forum 1995-1998
Need help identifying upgraded ECU
Old Apr 27, 2024 | 09:53 PM
gbooks's Avatar
gbooks
7th Gear
Default Need help identifying upgraded ECU
Hello Rennlist,
Long time lurker, first time poster. I am the steward of a 1996 Carrera 4 that received some "enhancements" sometime before 2013. One such enhancement was explained as a "performance chip" in the ECU. I have the ECU out of the car, so I decided to investigate. I have attached photos of what I found, which consists of a small board wired into the ECU. Does this look familiar to anyone? If so, please share whatever information you may know.
Thanks!
Top view of 1996 Porsche 911 993 ECU with "chip" in top right corner
1996 Porsche 911 993 ECU with "chip" another view
1996 Porsche 911 993 ECU with "chip" yet another view
1996 Porsche 911 993 ECU with the pink wire from the "chip" to a connector pin
1996 Porsche 911 993 ECU with the pink wire from the "chip" to a connector pin another view
Old Apr 28, 2024 | 02:13 PM
Gareth H's Avatar
Gareth H
Sorry, I can’t help with your query, but my car was recently remapped and the process was to remove the stock eprom (and put it somewhere safe), copy the contents onto a new eprom, fit it into the ECU , and then remap while running the car on a rolling road
Old Apr 28, 2024 | 02:41 PM
Porsche-ah's Avatar
Porsche-ah
1996 Motronic ECUs couldn't be "Chipped" or "Flashed" unless a piggy back board is soldered/added on. It looks like yours has it.
Old Apr 28, 2024 | 02:48 PM
gbooks's Avatar
gbooks
7th Gear
@Porsche-ah, exactly! I am looking for more information on the "piggy back board!"
Old Apr 28, 2024 | 04:45 PM
systemsc's Avatar
systemsc
Former Vendor
Originally Posted by gbooks
Hello Rennlist,
Thanks!
It's a Mickey Mouse immobilizer delete! This one doesn't have the daughter board attached, so there's no so-called "tuning" done.
Old Apr 28, 2024 | 04:55 PM
systemsc's Avatar
systemsc
Former Vendor
The 993 DME ECM technology didn't use EPROM. It's flash memory in the engine processor chip in the DME ECM. Consider contacting the "tuner" and determine what was really done.
Old Apr 28, 2024 | 08:50 PM
pp000830's Avatar
pp000830
Hi Gbooks,
ECU Doctors offeres the daughter board option for 1996 OBD-II. Speak to them first and see if it is theirs.
https://www.ecudoctors.com/
Andy
Old Apr 28, 2024 | 09:32 PM
systemsc's Avatar
systemsc
Former Vendor
Originally Posted by pp000830
Hi Gbooks,
Andy
Just make sure after the mod, that you avoid bumpy roads, and carry a spare DME ECM!
Old Apr 29, 2024 | 05:38 AM
Gareth H's Avatar
Gareth H
Only repeating what I was told by the guys who tuned my car told me, however I have known them for forty years, they are well known in motorsport circles, and I trust them explicitly.
Here’s an old post showing the Eprom, am I getting my terminology wrong?
https://rennlist.com/forums/993-foru...cognition.html
Old Apr 29, 2024 | 10:01 AM
Porsche-ah's Avatar
Porsche-ah
94-95 993s used Eproms (OBDI) like your above link
96 had some sort of board/system where the chip couldn't be flashed (OBDII)
97-98 could be flashed (OBDII)
Old Apr 29, 2024 | 11:14 AM
Gareth H's Avatar
Gareth H
Ah, ok, thanks, that explains it, my car is a 95, so my description of work done was accurate.
Old Apr 30, 2024 | 10:16 AM
GJSPIN's Avatar
GJSPIN
Regarding the bumpy road comment. You many want to install Sorbothane pieces (Ebay) under the ECU to help to absorb road vibrations.
Old Apr 30, 2024 | 12:25 PM
systemsc's Avatar
systemsc
Former Vendor
Good luck on that!
Old Apr 30, 2024 | 02:51 PM
Porsche-ah's Avatar
Porsche-ah
Why is that? Does the daughter board fit loosely?
Old Apr 30, 2024 | 03:07 PM
systemsc's Avatar
systemsc
Former Vendor
Here's one:
