Need help identifying upgraded ECU
Basic Sponsor
As some might say, "It's total Mickey Mouse".
Loren
Systems Consulting - Automotive Electronics
Specializing in Porsche cars
http://www.systemsc.com/
Loren
5th Gear
I appreciate your activity in this thread, and it sounds like you are not a fan of anything outside a stock ECU for a 1996. I tend to agree with you, and still hope to learn more about the current state of my ECU. Additionally, it seems like most / all model year 993 ECUs may be plug and play (programmed properly, of course) with a 1996. Maybe that can be clarified as well.
Hi Gbooks,
ECU Doctors offeres the daughter board option for 1996 OBD-II. Speak to them first and see if it is theirs.
https://www.ecudoctors.com/
Andy
Andy
Basic Sponsor
Thanks, @systemsc. What gives it away as an immobilizer delete? Is it the board that is mounted vertically on the ECU chassis? Or the pink wire connected to the furthest away pin? (or something different altogether?)
Thanks again, @systemsc. If I knew who the so called "tuner" was, I would have gone that route. Since I acquired the car with the ECU in its current state without information on what was done, I've come to the best source of information I know. (That's Rennlist!)
Thanks, Andy (@pp000830). I was already in discussions with ECU Doctors about my entire ECU / Immobilizer / Alarm before I posted. I am still discussing with them now.
Porsche-ah (05-05-2024)
5th Gear
@systemsc Thanks for all the information you have provided. The daughter board and pink wire were, as you correctly stated, an immobilizer delete installed in 2016. Additionally, it appears there is no chip in the ECU and it is otherwise stock, which is how it will remain for reliability purposes.
I would also like to thank all the other folks that have replied offering insights and information regarding my question.
