993 Forum 1995-1998
Clutch question
Old Jul 21, 2002 | 08:43 AM
Zumbera's Avatar
Zumbera
Post Clutch question
993 1994 c2cab...
During street driving when I push the clutch in to disengage and shift to the next gear (higher or lower), I hear a thud noise. Not when engaging but only when disengaging the gear. Havent seen it at moderate and high speeds. Only at normal to low speeds.
Normal... or problems??
Cheers
Zumbera
Old Jul 21, 2002 | 10:11 AM
pookee's Avatar
pookee
Post
Do you push your clutch pedal to the floor before you change gears? Sounds like you are not disengaging the the clutch fully.
Old Jul 21, 2002 | 12:26 PM
Zumbera's Avatar
Zumbera
Post
[quote]Originally posted by pookee:
<strong>Do you push your clutch pedal to the floor before you change gears? Sounds like you are not disengaging the the clutch fully.</strong><hr></blockquote>
Yes, I push the clutch pedal to the floor before changing gears. I recently had my slave cylinder done and the clutch does disengage fully
