993 Forum 1995-1998
Remove old stone guard on nb c2
Old 02-28-2024, 09:45 PM
Dutch4Scali
Dutch4Scali's Avatar
Default Remove old stone guard on nb c2
Hi all, I tried to remove the old stone guards on my 1995 993, but there’s a lot of residue left. These have probably been on there for 29 years….
Anyone has a good idea how to remove the residue?
any help is much appreciated!
Old 02-28-2024, 10:28 PM
mike cap
mike cap's Avatar
Steamer and/or 3M Adhesive Remover and plastic body shop scrapers. And lots of patience.
Dutch4Scali (02-28-2024)
Old 02-28-2024, 11:01 PM
71-3.0-911's Avatar
Goo gone or goof off work well. Even wd-40 will take it off.
Old 02-28-2024, 11:23 PM
Dutch4Scali
I tried Goo Gone but that didnt do much actually. I didnt use the special automotive version though.
Going to order the 3m adhesive remover and the plastic scrapers. Hope that helps.
Old 02-28-2024, 11:48 PM
pirahna
pirahna's Avatar
Steamer works best before removing the guards, if they have already been peeled off it won't work great on the adhesive residue.
An 3M adhesive eraser wheel works great but make sure you keep moving it around or you might damage the paint.
Dutch4Scali (03-01-2024)
Old 02-29-2024, 12:03 AM
71-3.0-911's Avatar
Be patient. Get the gel stuff and let it sit. Then you can simply wipe the adhesive off. I left it on the super nasty adhesive overnight on the rear seat area when I refinished my interior and was nearly able to peel it off the next day.
Old 02-29-2024, 12:27 AM
dalves11
dalves11's Avatar
Per previous recommendations, I used this stuff with good success with plastic razor blade
Amazon Amazon
The following 2 users liked this post by dalves11:
Dutch4Scali (03-01-2024), NC TRACKRAT (02-29-2024)
Old 02-29-2024, 09:53 AM
NC TRACKRAT
NC TRACKRAT's Avatar
Take it from dalves11 and me. In researching for what I knew would be a nasty job, I found out about the RAPID-TAC adhesive remover years ago by going to a local sign shop. The stuff works and will save you hours of time and aggravation.
Old 02-29-2024, 10:35 AM
crw
crw's Avatar
Consider goo gel and cover the area with saran wrap for a few days, that should work well
Old 02-29-2024, 02:05 PM
Dplus
Dplus's Avatar
https://www.amazon.com/gp/product/B0...1?ie=UTF8&th=1
That's what I used as well to get the adhesive off after using a stripper wheel to get the guard off.
Old 02-29-2024, 04:56 PM
abiazis
abiazis's Avatar
On my OEM guards used a combination of 3M adhesive remover, goo gone, iso alcohol and a plastic spatula......took some time.......
Good news is when you put the new ones on they usually peel off in one go, after getting an edge to come up and also if less than 7 years after initial application.....I use Suntek from Clearmask.......$24 a set......
Old 02-29-2024, 05:07 PM
pp000830
pp000830's Avatar
Received 1,458 Likes on 1,028 Posts
Hi Dutch,
Here is how I did it:
https://993servicerepair.blogspot.co...heel-arch.html
Keep in mind, if your car has been repainted with acrylic paint use extra care as the paint can be pulled off with the guards.
Andy
Old 02-29-2024, 05:53 PM
Dutch4Scali
Thanks all, ordered the plastic scraper, adhesive remove and wheel so hope I am all set!
Appreciate the help from you all!
Old 02-29-2024, 06:27 PM
JGuti
JGuti's Avatar
I just did this a couple weekends ago. I tried the 3m remover but I found that applying goo gone thick and scraping with a plastic razor blade while the goo gone was on worked well. The goo gone acted as lubrication and lessened my fear of paint damage.
Old guards
Adhesive left over
Before install of new guards
New guards
Old 03-01-2024, 01:37 AM
mike cap
mike cap's Avatar
It helps if you cut some rags into strips. Then lay them on the adhesive surface and soak with 3M adhesive remover. Let them sit for a while, and re-soak every once in a while it will keep the adhesive remover and contacts with the surface.
Quick Reply: Remove old stone guard on nb c2
