993 Forum 1995-1998
Introduction and 993 3.8 Engine Rebuild
Old 01-15-2024, 01:39 AM
  #31
saxen
saxen's Avatar
Originally Posted by os993
Dining room table? I love it!!
haha yeah, it was a bit more comfortable. This morning I woke up to -7 degree weather, maybe 15 degrees in the garage made the dining room a clear winner.
Originally Posted by 71-3.0-911
I did that rebuild 2 winters ago. What color is that? Thought about painting mine, decided to wait until next time. Looks fantastic.
Thank you. it’s a black powder coat wit some wrinkle texture added. I wanted something a bit different but not to loud.
Originally Posted by boomboomthump
You must be my twin. Black Varioram and likes to work on 993 projects on the dining room table.
Here's a pic I just dug up from a thread from 2021 when I did it. I did black mini-texture powder coat on mine...
Great minds think alike!! 100% twins other than your sweet Varioram script. I think I may have done a medium wrinkle, and pictures of your engine bay?
The following 2 users liked this post by saxen:
dalves11 (01-16-2024), sbsurfer (01-18-2024)
Old 01-15-2024, 02:13 AM
  #32
boomboomthump
boomboomthump's Avatar
Originally Posted by saxen
...and pictures of your engine bay?
Sure... here's my engine bay. 😂
But here's another dining room table shot of some of what will be in there. The cone filter may or may not be. Was just toying around with it.
Impeller housing is satin black powder. Gold paint + 2K clear on the impeller. Filled the timing tick mark with some red. Also gave the ISV and the tubing to it a quick polish... nothing crazy but they were tired looking.
The following 3 users liked this post by boomboomthump:
dalves11 (01-16-2024), sbsurfer (01-18-2024), SpeedyC2 (01-15-2024)
Old 01-15-2024, 12:35 PM
  #33
VladiD
VladiD's Avatar
@boomboomthump Goodness, that is some sexy sh*t. Definitely bookmarked for future reference, the golden impeller blades would look mighty fine on my ocean blue metallic.
Old 01-15-2024, 03:12 PM
  #34
EckFe1
EckFe1's Avatar
The Clewett pulley adds the midas touch.
Old 01-15-2024, 04:11 PM
  #35
a.cooled
a.cooled's Avatar
Default Clewett
in a sentence or two............the benefit and drawbacks of said pully is......................??
Old 01-15-2024, 05:01 PM
  #36
Bill Verburg
Bill Verburg's Avatar
In Saxon's case a single sheave pully is need to fit the space allotted by the 3.2 engine mount console he is using
Saxon's w/ 3.2 engine mount console and 911 crossbar and Clewett pulley
Mine in a similar install in my '76 C3, w/ RS single sheave pully and 993 RS engine mount console and 993 cross bar
Old 01-16-2024, 01:16 PM
  #37
saxen
saxen's Avatar
Man, that came out Great! I like the little details, red line, polished pipe and V-ram logo, looks great! That gold has me questioning my black fan, LOL! I ran a cone filter for the last 7 years on my stockfish 3.6, it was completely fine, it will probably look cleaner than my new air box setup. can't wait to see that come together.
Old 01-28-2024, 12:49 AM
  #38
saxen
saxen's Avatar
Just a bit of progress this week, dropped the car off for additional body harness cleanup and got the intake manifold mounted.
Also, I got to drool over a real RSR and a SCRS at the shop
Old 03-08-2024, 01:46 PM
  #39
saxen
saxen's Avatar
Small Update, the wiring harness on both the engine and body have been rebuilt.
I have no before pics, but the old harness was a hack job, chaotically finished in green electrical tape. This setup is so much cleaner with a main harness quick release.
Bill Verburg (03-08-2024), dalves11 (03-08-2024)
Old 03-31-2024, 12:49 PM
  #40
saxen
saxen's Avatar
Work has been hectic, but I was able to get a free day to start the install. Got a bunch of odds & ends finished up, and the engine is now mounted. I need a few more hours before we are ready to fire but we are getting close
Old 03-31-2024, 12:52 PM
  #41
saxen
saxen's Avatar
@Bill Verburg
there is a 1/4-3/8 inch gap between the Sheridan surround and the rubber skirt right now, I think I may be able to close that gap. If not I will either order a longer skirt or rivet a rubber extension to the skirt.
Old 03-31-2024, 03:20 PM
  #42
boomboomthump
Looking good!
Question, seems like you had some work done to stock 993 heads to fit the larger RS valves and you mentioned they were ported a bit too. Were the intake ports opened up to the larger RS diameter or did you keep them stock diameter? On the Varioram, the intake manifolds which lead down to the heads are also slightly larger on the RS to match the larger intake ports, so just curious if you went this route or not.
I'm planning an RS-spec 3.8L build. Thinking about getting RS heads ($$$$) and just selling my stock ones to offset costs.
Old 04-01-2024, 01:59 PM
  #43
TheBen
TheBen's Avatar
How much - average - would a 3.8 rebuild run at a competent Porsche specialist these days?
Old 04-01-2024, 06:22 PM
  #44
boomboomthump
Depending on what you're doing, I would say the range is $10k-50k. So "average" is somewhere in the middle there. I'd say most people are somewhere in the $20k-30k range if you're having a shop do the work (again, range varies on what you're doing).
BTW, that $10k is based on piston/cylinder set, DME reprogramming and just labor to drop the motor and swap the pistons/cylinders. Onwards and upwards from there with cams, valves, head work, etc.
In my case, I'm thinking of doing a full RS-spec motor. All labor myself with exception of machining the cases. Cost is right around $20k for parts + case machining + flashing my DME. No other labor.
Quick Reply: Introduction and 993 3.8 Engine Rebuild
