Does it make sense to replace springs only?
I just picked up a set of Eibach springs on eBay for $125, supposedly reduces the height by an inch or so.
Does it make sense to replace the springs only? AFAIK the shocks are the originals. Do I have to get the car aligned after repacing springs only?
Replacing shocks is looking kinda pricey, and I'm hoping to avoid it as the car handles well.
If you do a search, you'll see that most people recommend NOT replacing just springs. Those who have, have all posted that it was a mistake and that they would do the shocks if they could do it all over. If you are having a shop do the work, it'll cost nearly as much for just the shock change as it would if you did both. You'll be paying labor charges again down the road when you decide you want shocks. Do it right the first time, it'll save you in the end. Anytime your car is raised or lowered, you must do a proper alignment.
Sachin,
Once you pull the old shocks off the car, you will find that they are totally useless. I used to think my car handled pretty well with my ROW springs and 60,000 mile Monroes. Ha! You will need to have the car aligned and corner-balanced after the spring replacement, plus you will have already done the labor for the shock install. Bite the bullet. At the very least, get a set of Bilstein HDs. Or really bite the bullet and sell those Eibachs, and get a set of PSS-9s. BTW, I believe I've heard on this board that the Eibachs are a poor match with the Bilstein HDs... so forget option # 2, and go straight to option #3 (where option #1 was keeping your totally toasted stock shocks... blech).
Good luck.
Good luck.
Thx guys. I guess the springs will sit on the shelf for a bit. I was hoping to avoid the additional cost of doing the shocks too.
I'd love to step up to PSS9's but they are just too much for me right now. Blew my budget on the SC.
Are the Eibachs any good? I thought they were a good match with the Bilsteins (according to a Rennlist search)
Eibachs are the bottom of the barrel IMO.
Get the Bilstein HD's with the extra threads to lower the car and M030 springs. You will be much happier with that set up.
Steve, I had never heard about Eibachs being a bad match with Bilstein HDs. IMO they would be terrible with a set of high-mile stock Monroes though !! Whatever little life left in your stock shocks/struts will be used in a hurry with the new lower ride height.
Of all the aftermarket springs, Eibachs are probably the softest. Quite close to the original springs in my estimation. So, the only reason to use them would be to lower the car. And the only way I would install them is with Bilstein HDs. (which is exactly what i did by the way , in addition to RS swaybars).
If I would have had a crystal ball at the time of my purchase, I would have waited for Gert's extra thread Bilsteins and used M030 springs.
As others have said, the approx. $500 -$700 to install with the old shocks and align would be money well wasted.
as usual, just my 2 cents; and YMMV ....( Your Monroes May Very)
I agree with the others: definitely go with Gert's xtra thread bilsteins and either the m030 springs or H&R springs (depending on how low you want to take the car). For the price you paid, you should be able to sell the eibachs and not lose any money.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
