Tire Inflator Recommendations
My car is parked in an underground parking garage thirty floors below my residence. The garage does not have an air compressor. I have ac power connected to my battery maintainer. I live in Philly. I don't want get mugged, robbed, carjacked or worse using a tire pump at a Philly gas station. Any recommendations for a portable tire Inflator based on my circumstances will be appreciated. I saw the tire Inflator in the link on TV. Thanks in advance!!
https://getbullseyepro.com/?gad_source=1&gclid=Cj0KCQiA3uGqBhDdARIsAFeJ5r2ta2ReG3kNJqwFLOn5bdYmZABS 0jJ5ED0p4K8Wi4-YJtsP-UUcqAIaAooKEALw_wcB
Addicted Specialist
You want this:
Seriously fast for its size. Has gotten me and kids out of a jam several times, even when filling a tire on a suburban. Fast inflation, small, light. You can't miss on this one.
Edward
Amazon.com: VIAIR 85P - 00085 Portable Plug In Cigarette Lighter Port Compressor Kit, Tire Inflator, Air Pump w/ Screw-on Tire Chuck For up to 31 inch tires : Viair: Everything Else
Edward
NC TRACKRAT (11-19-2023)
Originally Posted by Edward
You want this:
Edward
Edward
Hi Harry,
This is the one I have used for years, had to inflate the spare a few times with it. Also, great for bicycle tires and basketballs!
https://www.harborfreight.com/air-to...tor-63745.html
Andy
Andy
It depends what cordless tools you have but we have a lot of DeWalt stuff and this is easily my favorite <$100 purchase ever. I use it all the time and have not used my megabucks super nice California Air tools compressor a single time since getting it.
But I think the others above are equally right. Any number of great choices on the market these days.
sdm100 (11-20-2023)
Paolo1 (11-19-2023)
Addicted Specialist
Edward
Does anyone know if the cigarette plug in type tire inflators vs Milwaukee/DeWalt pressurize automobile tires from roughly 20PSI to 35PSI in similar time? Thanks for your responses. I've learned a lot.
The battery ones are 10x more connevnient because you don't have to reroute the cord through two different doors to do both sides. And they are set and forget. Set your pressure to 39 lbs or whatever, hit the go button and walk away. A few min later it shuts off and you just move it to the next tire. it's honestly the easiest thing you can do to a car short of opening a door (assuming a regular car door - it easier to do than open the door to my F355 or V8 Vantage that requires a tiny bit of knowledge).
I'd rather give Jeff Bezos less towards his fiancee's 2.5 million engagement ring if possible.
The small but important detail missing from some of these recommendations is that for the Dewalt / Milwaukee devices you not only need the device, you also need an expensive battery and charger (unless you already are using the brand for other power tools, etc.)
Today on Amazon the Milwaukee is $139, the oem battery and charger are $155, making the total about $300.
Since your car battery is on charge, I would just keep this $75 powered-by-the-car-battery unit in the trunk, then you can use it whenever you want, without carrying it down from your living area.
We've all plugged something into the cigarette lighter only to discover that the fuse is bad or blown, this eliminates that by having alligator clips to connect to the car battery. The hose is plenty long for a 911, but I added an extension so it's more convenient when I need to use it on my full-size van.
If you instead want an expensive battery-powered unit, I have the Dewalt and like it fine, however a reputable youtube channel tested them, and the Milwaukee is much faster.
Hi Harry,
Keep in mind the ones that use batteries cost a lot more and become inoperable when the battery goes bad. My experience with cordless tools is that getting a replacement battery after a few years is problematic. The ones that plug into the cigarette lighter are inexpensive and will last the life of your car.
Andy
Andy
ronnie993tt (11-26-2023)
