Strut BRace Install...
My next task.
I am about to install my strut brace. Just curious, and forgive the naive question, do the bolts need to be tightened to a certain setting, i.e. torqued? or is typical tightening enough?
Lastly, I assume it requires a 10mm wrench, correct?
TIA for the help.
Still learning...
TIA for the help.
Still learning...
Mark
Assume you are referring to the strut tower nuts. Tighten them to 24 ft lbs. I also used Locktite when I did mine. As I recall the nuts are larger than 10mm, but I assume you'll be able to figure that out w/o my going to my garage at 12:30am to check for you
Remember to add a little pretension to the bar - pushing the towers apart (about 1/2 turn).
