H&R coilover height adjustment
Hi,
The PO lowered the car a little too much, and I tried to adjust the ride height today, with little success.
I stole the image below from Carnewal, the left pair of coilovers is for the rear, the ones on the right is for the front.
On the ones in the rear, height adjustment is made via the lower most right (red arrow), right? Or do you adjust height like the fronts, via the 2 rings at the bottom of the spring?
Also, is the sway bar end link attachment (blue arrow) welded to the lower most right (red arrow)? I couldn't get it to move at all.
Thanks!
Thanks!
![](http://www.ghettoengineering.com/porsche/pics/hrcoilover.jpg)
Hi Hatchy,
OK - under the springs - you will see two collars - the one that sits under the spring "perch" will raise the spring "up" or "down". Under that collar is the "locking" ring. You have to loosen that one to move the top collar.
So - in other words... In the rears - seperate the top two collars - then screw the "top" ring "up" to raise the height. When you are done - move the second ring up too - to lock the top ring.
The lower lock tab (on the rears - the 3rd ring down) locks the drop-link (to the sway) mount in place - and for your install - has nothing to do with adjusting ride height..??
Does that make sense???
Post back with any other questions, OK?
John
John
Originally posted by hatchy
John, thanks, that makes perfect sense. So the rears are adjusted just like the fronts then. Thanks again!
John, thanks, that makes perfect sense. So the rears are adjusted just like the fronts then......
Also - if you need a set of Bilstein wrenches to loosen the rears - let me know - and I'll loan you mine. No charge. Just return them when you are done, OK?
Best to you,
John
You guys are the best! ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I have a set of wrenches form another set of coilovers, it fits the top perch so I think I am okay, but thanks for offering!
I dont know much about the H&Rs, is the rebound/compression adjustable?
.....I have a set of wrenches form another set of coilovers, it fits the top perch...
Best to you..!
John
Here's a photo of my H&R rears, you can see the three adjusters that John mentioned. The top 2 use the same wrench, the bottom one is obviously smaller. I have not adjusted the fronts yet, is that small one the same
as the front adjuster??
Bruce
Bruce
Bruce, check your PM box; i sent you a message a few weeks ago. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
max
max
Originally posted by CentralCoastC4S
.... I have not adjusted the fronts yet, is that small one the same
Yep - the same size wrenches for the fronts will work just fine..!
Best to you!
John
You might want to consider the effect before making any changes. See link :
https://rennlist.com/forums/showthre...threadid=14467
