Tightening torque
LimeyBoy (05-13-2023)
The torque for the starter is different than the studs securing the bell housing to the crankcase (which I believe you'’re pointing to in your first picture).
hope this helps.
hope this helps.
I am a bit surprised at that torque of bell to engine... That 17 is an M8 torque spec, those are M10 studs, which are typically ~34 ft lbs. I have had my engine and trans apart no less than 10 times and have always torqued bell to motor at 35 ft-lbs.
I scoured the manual and could not find the spec in there also... I did find starter to trans at 34 ft-lbs.
