993 Forum 1995-1998
Don’t underestimate 5mm spacers
Old 04-11-2023, 02:10 PM
403portside
403portside's Avatar
Default Don’t underestimate 5mm spacers
I was looking for a slightly more filled out look to my C2S after installing m033 springs + Porsche Classic Green shocks. I had 5mm spacers installed yesterday and I have to say the car looks perfect now. It looked a little too tucked previously. Now it actually looks more “factory”. The wheels don’t stick out really but they just look more aggressive. Highly recommend this upgrade if you’re looking for a subtle but worthy improvement to your stance.
Pics are not apples to apples but hopefully you can see the before/after difference.
Before
After
After
After
Old 04-11-2023, 02:39 PM
JSF
JSF's Avatar
Looks great. The spacers do help quite a lot.
The following 2 users liked this post by JSF:
403portside (04-11-2023), rk-d (04-12-2023)
Old 04-12-2023, 08:43 AM
skiver
skiver's Avatar
Pics look good!
Which spacers did you use and did you need to extend the wheel bolts?
did you find any rubbing against the fenders?
Old 04-12-2023, 09:35 AM
rk-d
rk-d's Avatar
Received 6,290 Likes on 2,753 Posts
Wheels are funny like that. In reality, 5mm is such a minuscule distance and yet when it comes to stance and ride height, it can be a make or break kind of thing.
403portside (04-12-2023)
Old 04-12-2023, 11:49 AM
403portside
Originally Posted by skiver
Pics look good!
Nothing extra was needed and haven’t noticed any rubbing thus far. I bought the ones from FD Motorsports.
Old 04-12-2023, 07:03 PM
os993
os993's Avatar
Is there a safety concern adding these 5mm spacers without bolts? Less thread to torque down the wheels?
Old 04-12-2023, 07:04 PM
Bxstr
Bxstr's Avatar
Received 2,993 Likes on 2,061 Posts
Looks great. Enjoy it.
Old 04-12-2023, 08:15 PM
akrca4
akrca4's Avatar
You can go 7mm in the rear if you like. I usually put 5mm in the front and 7mm in the rear when I have the turbo twists on.
Old 04-12-2023, 08:33 PM
Ed Hughes
Ed Hughes's Avatar
I have 7mm in front, not for looks, but they mitigated understeer a tad on tight corners on our mountain roads. Looks weren’t a big concern, but I guess they look good.
Old 04-12-2023, 08:53 PM
Gbos1
Gbos1's Avatar
No not with 5mm. OE is fine.
Old 04-13-2023, 01:31 AM
403portside
I’ve also noticed less understeer with 5mm all around, but wasn’t expecting it. It was a nice surprise.
Ed Hughes (04-13-2023)
Old 04-14-2023, 12:47 PM
Gator06
Gator06's Avatar
Went with 7MM spacers on my 993 cab, front and rear. No issues with stock bolts/lugs, torqued appropriately. Subtle improvement aesthetically, and zero negatives ride/handling wise.
Old 04-15-2023, 08:09 PM
MC 968CS
MC 968CS's Avatar
Did you use longer bolts with 7mm, or both 7mm and 5mm seem fine with oem bolts?
Old 04-15-2023, 10:17 PM
Gator06
Gator06's Avatar
Both are fine with OEM bolts. Literally one post above yours.
MC 968CS (04-15-2023)
Old 04-16-2023, 12:31 PM
Holger3.2
Holger3.2's Avatar
I realized that the needed bolt lengths depends on the rim you use.
On OEM holospokes no issues with standard bolts on 5mm spacer (no idea about 7mm), on OZ or BBS you need longer bolts, there the nut will cover just half of its thread, which seems a little scant.
If you buy eg. KW 5mm spacer, they come with 5mm longer bolts.
Quick Reply: Don’t underestimate 5mm spacers
