993 Forum 1995-1998
Looking for a set...
Old May 4, 2004 | 05:39 PM
  #31
Viken's Avatar
Viken
Keeper of the Truth
Originally posted by Randy M
The C4S and the TT has to have a really close rolling circumference front and rear as well right?
Yes. I would keep the diameters really close to stock on any car, if I could help it. The same applies to 2WD cars as the ABS is programmed for certain rolling circumferences.
Old May 4, 2004 | 05:42 PM
  #32
Agro1's Avatar
Agro1
Thanks for all the info guys and thanks for the referral John D. - I'll give those guys a call. My car has S-02's in the rear and get this, Yokohama Nexus in the front.
Don't ask, the PO put them on...So, are the S-02's really that bad ? I've only driven the car about 50 miles and couldn't really tell, they seemed ok to me. Maybe the worn out lame ride height suspension is masking the crappy tires Thanks again guys
Old May 4, 2004 | 05:46 PM
  #33
DJ's Avatar
DJ
Haiku Grasshoppa
Can I Drove Your Car?
Of course the S-02's really are that bad. Why else would that tire dealer have "several sets of 90%+ S02s ". After only using up less than ten per cent of the tread, everyone got rid of them.
  #34
Randy M's Avatar
Randy M
I'll get into it next time around as it sounds like I'll have crappy tires for the next 10K miles. Thanks Viken.
Old May 4, 2004 | 05:50 PM
  #35
DJ's Avatar
DJ
Haiku Grasshoppa
Let me drove your car. I'll have them wore out by Monday.
Old May 4, 2004 | 05:51 PM
  #36
Agro1's Avatar
Agro1
Bummer man...I'm not questioning you, but can you tell me exactly why they are so bad ? Excessive wear, prone to grenading at high speeds, noisy, bad in the wet ? As long as they don't have some sort of massive failure at speed and are fairly sticky, I'm fine with noise and minor stuff like that...
Old May 4, 2004 | 05:52 PM
  #37
Viken's Avatar
Viken
Keeper of the Truth
Naah, it'll be Friday noon.
Old May 4, 2004 | 05:54 PM
  #38
Randy M's Avatar
Randy M
Well I am participating at my first DE 6/27 at PIR, hopefully.
On another note. What is the whole "can I drove your car" bit about? And this haiku stuff? Something to do with that ghettoracer guy and that year long thread on the other board? Does he go up and down the west coast wrecking cars or somethin'?
Old May 4, 2004 | 05:58 PM
  #39
nman413's Avatar
nman413
Randy, I'll let you know I'm getting 235/295 PS2s for my TT and we'll see how they work.
Old May 4, 2004 | 05:59 PM
  #40
nman413's Avatar
nman413
Viken, what is the rolling diameter ratio (?) that's not to be exceeded that would trigger the ABS?
Old May 4, 2004 | 06:01 PM
  #41
Viken's Avatar
Viken
Keeper of the Truth
I think if you stayed within 1/2" of the original diameter, you should be OK.
Old May 4, 2004 | 06:02 PM
  #42
Randy M's Avatar
Randy M
Please do. I've always wanted to get bigger tires on all of the cars I've had. I really have no rationalle for it though. I'm not particularly skilled enough to need bigger tires. Looking forward to that DE.
Old May 4, 2004 | 06:18 PM
  #43
Viken's Avatar
Viken
Keeper of the Truth
That's good thinking. No real need to go for bigger tires without a valid reason.
Old May 4, 2004 | 06:27 PM
  #44
DJ's Avatar
DJ
Haiku Grasshoppa
I wasn't planning on picking it up until Sunday morning...
Old May 4, 2004 | 06:35 PM
  #45
Terry Adams's Avatar
Terry Adams
Veteran: Army
Just checked with a friend at Michelin, and got back from my tire and suspension shop, which checked the specs. In the next 30 days my Pirelli System Assimetricos (a very good tire) will be ready for a change, and I will go with PS2 in
Size MSPN Rim Width Range Diameter Porsche OEM (though not 993, I guess)
235/40ZR18 N2 95853 8.0-9.5 25.4 Yes
295/30ZR18/XL N2 49127 10.0-11.0 25.0 Yes
My only valid reason is Phil's are bigger than mine . Seriously, I want to try the PS2, even if it looks strange.
icerbofh, where you getting yours?
