RS Mount Bolt Question
I was advised on another thread that my engine mounts were way past gone and II just started replacing with RS mounts.
I have the engine supported by the jack and after putting in the RS mount bolt I notice it doesn't reach all the way through the hole that connects to the engine carrier. Bolt only gets about half way through.
Can someone verify that P/N 900-082-030-02 is the correct bolt? If it is I'll just jack it up another 1.5 to 2 inches.
thanks
thanks
thanks
thanks
Bolt is 105mm so I guess engine is just sunk down on the other mount. Will gently lift it. Thanks
Update:
Done. Gotta say that was pretty easy other than doing the one man torque wrench stretch.
Update:
SpeedyC2 (05-13-2022)
