993 Forum 1995-1998
Need CS/930 steering wheel install help
Old May 3, 2022 | 08:49 PM
motobri's Avatar
motobri
Still trying to figure out how to get the horn working. This is the only part left but no clue where I would mount it?
Anyone?
Or maybe this is what I need?
https://www.fvd.net/us-en/PCG3478350...s-genuine.html
Old Nov 6, 2022 | 10:07 PM
motobri's Avatar
motobri
Still don't have a horn. Anyone have any idea on how to get the horn connected in the hub? Is it possible now that the OEM orange clockspring ring is removed?
Old Nov 7, 2022 | 01:24 PM
orbeamike's Avatar
orbeamike
Aside from the hub adapter, this should be almost identical install as the RS steering wheel, have you made the following required mods to the harness to turn off the airbag light and activate the horn circuit? You need the L contact, resister soldered to the orange connector, and the yellow horn wire attached to the red connector.
Old Nov 7, 2022 | 01:38 PM
Type911uk's Avatar
Type911uk
Former Vendor
You have one of these fitted?
I suspect not, its not in your pic of parts and is the horn contact!
Old Nov 7, 2022 | 01:45 PM
motobri's Avatar
motobri
Yes, but don't know where to connect the 2 wires and in the hub to? Are they not needed?
Old Jan 29, 2023 | 01:28 PM
Manual991's Avatar
Manual991
If you didn't already get your answer, I just took mine apart. There's only 1 wire from the hub to the horn ring. Here's a picture of everything that I removed. The hub on the left is the MOMO hub that I used with an Atiwe adapter. The hub on the right is the Porsche/Atiwe hub came on the steering wheel that I had but I used the MOMO hub. Both only have 1 wire.
