993 Forum 1995-1998
ISV
Old Jan 6, 2022 | 02:53 PM
danie's Avatar
danie
Default ISV
Sorry for writing i'm using the translator.
I would like to know the operation of the valve isv regulation system. Where it comes from and where the flow of passing gases goes? Some pattern. Thank you very much
Old Jan 6, 2022 | 05:21 PM
boomboomthump's Avatar
boomboomthump
At idle, the valve position is opened, which allows air to bypass the throttle plate (which is closed because at idle you are not stepping on the accelerator, opening the plates). The air comes "from" the intake coupler, just after the air box and MAF, right before the throttle plate. The "to" returns the air behind the (closed) throttle plate. This again allows a small bit of air to enter the intake manifold, allowing the car to idle.
When you are not idling, the valve closes so that air cannot bypass the throttle plate, and instead air ratio into the manifold is controlled by the throttle position sensor (how much you are accelerating). The valve typically gets gummed up and gets stuck in the closed or partially closed position. So at idle, this leads to a stumble or lack of idle completely due to lack of air.
Old Jan 6, 2022 | 05:23 PM
pp000830's Avatar
pp000830
Hi Danie,
The idle air control valve is controlled by the Bosch Motronic ECU. The ECU keeps a check on the engine's idle speed. The ECU uses the Idle control Valve to control the amount of air that is allowed to bypass the throttle body supplying air to the intake manifold, so as to keep the engine idle speed constant.
Lots of articles on the internet explaining its function.
It is a service item on our cars that needs to be cleaned regularly. It can be tested. Here is a page on the subject:
https://993servicerepair.blogspot.co...r-robbing.html
Andy
Old Jan 6, 2022 | 05:33 PM
boomboomthump
Grabbed these videos from my instagram. ISV overview I did last year as part of a complete overview of how the Varioram intake works.
File Type: mov
File Type: mov
File Type: mov
File Type: mov
File Type: mov
File Type: mov
File Type: mov
File Type: mov
File Type: mov
Old Jan 7, 2022 | 12:41 AM
993c4ie's Avatar
993c4ie
See this thread https://rennlist.com/forums/993-foru...valve-isv.html
Very detailed explaination.
Old Jan 7, 2022 | 02:58 PM
danie's Avatar
danie
Thank you all from Italy
