Trany grind
Perhaps, but it's what I read here is supposed to be the proper factory type fill. It will if anything give me a baseline to work from in trying other gear oils like Redline, etc. As I mentioned, I have no idea what is in the case now or even if it has ever been changed.
I have Mobilube PTX in my car now. https://www.suncoastparts.com/product/00004320420L.html
It feels really good once warmed up. During cold shifts it can be a bit challenging.
I still think the OE Porsche fill is the best all around fluid https://www.suncoastparts.com/product/99991754600.html
My.02
My.02
Had issue with Lucas when cold and Cold like Frosty cold...where is OP?
at what temp is issue?
Did u test engine mounts? Sagging tips?
have you cleaned shift linkage ? After removing ice :>}
I run the Redline 75W 90 in both my 1988G & 993 C4S and with great success. Frankly, I have the Mobilube PTX on hand and may drain/fill 993 C4S with it but just to try and see how it is vs. Redline.
For another data point, on my 96 C2 with an LSD, I refilled my factory-fill with SWEPCO 201, it was colored blue, and shifting was the same as before - like buttah.
With that said, I've always double-clutched all downshifts, so my synchro's love me.
i have new engine mounts and golden rod, short shift, and all replaceable shift bushings
when I drive for a while in hotter weather ( was 30-40 C here for most of the summer) and motor gets closer to 3 or 4 o’clock temp. this is when miner grinding occurs, shifting also feels loser
I’m using Castro 75W-90
cheers
