993 Forum 1995-1998
Invinca-Shield Mess
Old 04-14-2004, 01:46 AM
Pete Lech
Lifetime Member
Pete Lech's Avatar
Default Re: OEM Material Removal
Originally posted by campbesl
Gentlemen,
My car needs the clear protector replaced on the rear fenders. What is the proper way to remove the OEM stuff prior to using the InvincaShield kit to install the new panels?
Scott
My car is dark, so I parked it out in the sun for an hour. Then I peeled the old rear fender stoneguard piece off slowly. Removing the residual glue was a problem until I found this technique: after softening the residual adhesive with 3M Adhesive remover, use the teflon squeegee that comes in the Invincashield kit to gently scrape it off.
I am very happy with the look of the replacement Invincashield piece.
Quick Reply: Invinca-Shield Mess
