993 Forum 1995-1998
993 wheel upgrade
Old Aug 9, 2021 | 01:12 AM
Tmcnearney1's Avatar
Tmcnearney1
From: Tucson, AZ: November to May: Carbondale, CO; June to October.
Default 993 wheel upgrade
I have a 97-993 C2 Cab with 17 inch wheels. I’d like to upgrade to 18’s. Can anyone suggest the best size wheels?
also do I need to strengthen the front suspension?
finally I know some people use spacers to push the wheel outward, is this necessary-and/or beneficial
Any ideas would be helpful
TMc
Old Aug 9, 2021 | 11:58 AM
71-3.0-911's Avatar
71-3.0-911
18s are pretty normal around here. I believe since you are a 97, you should already have the steering brace installed. It'll be a simple check of your steering rack to verify. On a cab, this will be essential to 18s.
As far as spacers on wheels, this can be overcome with the correct offsets for your wheels. If those offsets are not available in your wheel of choice, spacers can help resolve that. Depending on spacer thickness, you may need to run longer wheel studs.
Lots of topics on this stuff but that should help get you started.
-Scott
Old Aug 9, 2021 | 12:21 PM
Cactus's Avatar
Cactus
Noodle Jr.
I have 18" MY02 wheels with 5mm spacers all around.
Old Aug 9, 2021 | 01:55 PM
rrc715's Avatar
rrc715
The most common offsets for a NB are front ET50 rear ET65. There are others that will work but this is a good starting point. Good luck on your hunt. RRC
Old Aug 9, 2021 | 08:35 PM
Bill Verburg's Avatar
Bill Verburg
TMc
Might as well stick w/ stock
8ET52 front w/ 225/40 & 10ET65 w/ 265/35
for track use there is a small edge from widening the track by a few mm, for the street, das macht nichts
some use small spacers w/ the above because they think it looks cool, the down side is less bite by the lug nuts or heavy spacers
Old Aug 11, 2021 | 11:58 PM
TJ993's Avatar
TJ993
Varying from the above mentioned offsets may be required or desired if for example you wish to go wider than 8 & 10 (x18) usual widths and offsets for say Track useage?
Old Aug 12, 2021 | 12:28 PM
Bill Verburg
true , but since he has a cab....
I have used 8.5 and 9 on the front of mine but 10 is about the limit for max performance in back, anything wider will usually involve performance compromises like raised ride height
optimized performance will be obtained w/o compromise w/ 8.5 ET54 and 10 ET65, 245/35 and 285/30
