Ignition Key is not turning
I need help.
I just returned from a short drive and now the ignition key is not turning. I tried both keys with no success.
Any suggestions would be appreciated.
Maybe a dumb thing, but check to see if the steering wheel is locked at full turn either direction.
Steering wheel yes
If yours is ever notchy or fails to release, I wouldn’t drive it anymore until the lock is removed. You’ll end up somewhere you don’t really want to be.
not to scare, but these cars are older
First thing I did after making sure the steering lock wasn't stopping the movement of the ignition tumbler was to squirt some lock lubricant into the slot. Freed the lock and my mind as well, as I thought I'd be looking at a new ignition lock.
