I can’t even remember when these were made but it’s definitely the OG crew. Early 2000’s or so.
A Rennlist member designed and assembled desktop clocks made from 993 parts.
Mine was special custom because I wanted aluminum gauges to match my car. All the others were made black.
I wasn't able to get in on some of the original runs by Andreas but I commissioned one from him several years later where I supplied the clock and block of myrtlewood (local wood native to Oregon). I had him integrate in an actual clock adjustment switch as well. Andreas then worked his skills to produce this fine example. I was also thinking the aluminum gauge face but ended up going with the standard. Yours without the cutouts looks great!
