Numeric Racing Short Shifter
#287
I don't know the numbers but the tecquipment **** on the 993 is significantly heavier than stock and is a massive improvement
#288
The tecquipment **** is plastic with an alloy insert. It may be an improvement if you do not change gear quickly but for a fast change you need a light **** - see the balsa gear ***** used by Porsche and latterly Singer. A heavy alloy **** may look cool but there is a lot of mass to overcome when you want to move it.
#289
Got under the car and the connection between the GR (forward rod) and the numeric are solid. I looked at the trans mount and it had some cracks. Will replace that and see if there is any improvement.
If no improvement, I will try the stock forward rod, then a lighter shift ****. hopefully It doesn't come down to removing the Numeric box.
#290
You can't use the stock forward stabiliser rod with the NR shifter. Suggest you try:
a) fitting stock **** (easiest option)
b) replace the Goldenrod (if fitted) with the stock rod and retest
#291
Numeric shortshifter
I might come back to you for purchase?
A month ago ii ordered a 964/993 short shifter and golden rod.
I need it for my conversion from C4 to C2.
After payment I got an order confirmation, but heared nothing ever since. No communication, no responce. Nothing.
I am very concerned that they are out of business.
As I live in Europe, I cannot check. Does anybody live in their area to check what is going on?
#293
I returned mine before ever trying to install based on the learnings I read about here
#294
Hello Cobalt,
#295
Sounds a bit more reassuring.
The new golden rod is new to me. You think they would deliver the updated one to me?. Update is always better.
I am not in an extreme hurry, but hope we can cumunicate with the company in near future,
#296
I think it’s still in prototype stage
#297
Picked up the replica teq **** and it still vibrates at high rpm. Will ditch the goldenrod and see how it goes. easy swap!
#298
At Numeric today. They are getting caught up with the order backlog. Shifters as far as the eye can see. Also getting the prototype shift rod installed on my 993. Should be a big improvement over the golden rod. Zero play in this u-joint, and an easier length adjustment system.
The following 4 users liked this post by acr89:
anguilla1980 (09-29-2023),
c2_peter (10-02-2023),
M. Schneider (10-02-2023),
YellowDieselGolf (09-30-2023)
#299
How is the shifter with the prototype rod? I was glad the see the back log getting cleared up. I’ve been waiting a while for my shifter and golden rod.
#300
I'd be interested in a Group Buy.
