About to pull the trigger on a 993 - New to me 993!
#47
Thanks, yes we did turn the headlights on but I cannot remember if we pulled or pushed the stalk.
Also, I was told I would need to keep the 993 on trickle charger if the car is not used more than 2 weeks because the alarm drains the battery. Do 2 weeks seem normal or not?
I read people having drain battery issues on 933 have their battery drained in 3 to 4 days (or less). The alarm seem to work fine (no random activation), there is no key fob, just the regular metal key. I‘ll ask if the car is equipped with a tracker. There was an aftermarket stereo and aftermarket CD changer that were installed before but that the seller removed them (currently a Becker stereo).
#48
So I had more driving time with the 993 during the 2nd day with the owner. I drove more than 100km, mostly motorway but a fair amount of mountain roads.
Motorway driving made me realize the car is a bit noisy, NVH of the 993 is by definition not as good as the modern 911s that I was able to drive in more recent years (997.2, 991.2 and 992).
It's funny because the 1st time I drove a 993, that was in 2007 and I also drove a 964 prior to the 993 that day and my impression at that time was that the 993 was much more refined than the 964 in terms of NVH but also controls of the car (steering, gearshift lever). I guess that's what they call progress.
I am now fully used to the pedal box not aligned with the driver's seat.
The clutch operation is still a learning curve for me at take off (have not driven a manual gearbox for years so the problem is more with me than the 993).
I start to really like the hard brake pedal, very easy to modulate the braking.
The highlight for me is the steering. Quite heavy in a good sense and you can point and shoot and the car will go where you point at.
Gearshift is tight, gearshift longitudinal travel is not as bad as what I could read even if I would still consider a short shifter. Lateral move of the shifter is crisp - I like it.
The mountains road is where the car shines. I am only scratching the surface but I have a feeling that carving mountain roads will be an amazing experience with a 993.
Refueling before hitting the mountain roads
One question though : how to protect the front end from stone chips when I drive the car back home? Does the use of Scotch Blue Painter tape is OK or not (would not look very good but I don't care, I will just drive the car straight back home).
Thanks in advance,
Thanks in advance,
masti99 (05-30-2021)
#49
Thanks in advance,
Thanks in advance,
#50
Consider wrapping the front half of the car at least in clear stone guard before your trip
#51
Thanks in advance,
Thanks in advance,
Look good? This is what you get when you cross blue painter tape with OCD and a brand new (silver) car. This was two miles from the dealership because I was too embarrassed to do it there.
#55
Must have taken you a very long time but I admire the perseverance and the dedication to the task!!
Porsche must have gotten the inspiration for Miami Blue from you
Thank you!
#56
@sacman : Were there some areas where you put a double (or more) layer of painter tape such as front wings, frunk, front bumper?
#58
Small update : front tires were changed (previous ones had to be changed and were not well balanced hence steering wheel vibrations present above 80mph). Problem sorted now and no more vibrations.
#59
QN
#60
Honestly, I think would just double tape the entire bumper and call it a day. In Northern California during the summer, it helped with dead the bugs a lot. As for putting on the clear bra, I found that it's cheaper and more enjoyable to just enjoy the car and repaint the bumper whenever it doesn't match the rest of the car. These car a meant to be driven and you'll get back your money in ten folds from the driving experience. I stop worrying about paint chips once I decided that it is a toy to serve me and I'm not saving it for the next owner.
QN
QN
sacman (05-06-2021)
