993 Forum 1995-1998
Alternator Question
Old Jan 25, 2021 | 02:40 AM
geolab's Avatar
geolab
Originally Posted by boomboomthump
no where around here had M6 bolts with enough thread to thread all the way down and push against the alternator itself.
Fun times.
try it next time , you won't be deceived
all you need is that the bearing moves a tad , and loosen
10 cms long bolts, are great for this
Evenmore, since your fan was out, you could have even placed three small metal sheets where bolts meet alternator
Originally Posted by blue ocean
Just went to buy a small chisel to see if I can get it behind the sleeve and move it enough to get a puller behind it.
I would have freaked out , with a chisel, to misalign the alternator axle, but I understand you did this on old alternator
Old Jan 26, 2021 | 12:55 PM
Blue Ocean's Avatar
Blue Ocean
Thanks 95_993 and pp000830!
I did notice the remanufactured alt had a different wire mounting block but was planning on using it as is until seeing your post.
I will definitely switch that out!
I haven't installed the new alt yet because I decided to order a new fan bearing and replace it while I was in there. It should arrive today,
Gotta love Rennlist!
Old Jan 26, 2021 | 06:57 PM
95_993's Avatar
95_993
Glad it worked out Blue Ocean. I saw this issue on a reman alternator directly from Porsche last year and thought it was worth bringing Steen room to it. I found the thread I shared helpful at the time.
Old Jan 27, 2021 | 03:04 AM
993c4ie's Avatar
993c4ie
Did that yesterday, worked like a threat. Very minor marking on the alternator body from the 3 bolts. Wat better and safer than using a puller onto the fan.
