Suspension Upgrade 96 C4S
I am looking into upgrading my suspension. One of my friends has recommended the H&R
coil over kit. I understand that the kit rides rather rough but I am looking to get maximum performance. Is there a better kit that I should look at or is the H&R about as good as I can get? Thankyou very much in advance for any help!
Originally posted by Jim_me:
<STRONG>I am looking into upgrading my suspension. One of my friends has recommended the H&R
coil over kit. I understand that the kit rides rather rough but I am looking to get maximum performance. Is there a better kit that I should look at or is the H&R about as good as I can get? Thankyou very much in advance for any help!</STRONG>
It would be a good idea to check into the suspension FAQ on Robin Sun's web site: http://p-car.com
-Matt
Lifetime Rennlist Member
Also have a look at the FVD suspension setup. A number of us have that kit installed and are very happy with it.
Schatz Motorsport
Schatz Motorsport
I did a complete upgrade on my 97C2S last year.. Bilsteins RSR Motorsports w/ Eibach Springs @500lbs front, 600 back, monoballs with camber plates, factory RSR/GT2 front and rear swaybars, and a Brey Krause Strut Bar... $4,579 total plus install.
Keeping in mind Matt's comment about one man's stiff ride is another's pin cushion, I feel that this is an excellent "combination" setup. I go much faster and happier at the track events I attend, and I am comfortable with the performance ride for the street.
I have upgraded the suspension on my '98 C2S with the H&R sport setup with Porsche RS adjustable anti-sway bars retaining the stock rubber bushed upper strut towers. I believe the spring rates in the ballpark of 290# front and 360# rear. I also lowered the car to Euro RS rideheight and I use Fikse 17" rims with 245/45ZR17 front tires and 315/35ZR17 rear tires. To me, it's perfectly streetable.
To go one step further than this you could get the H&R "Supercup" setup with stiffer spring rates, the tender springs, and monoball upper struts. I belive this is what the Euro RS would use. I did not want to make this step.
