993 Forum 1995-1998
OEM Battery Alternative??
Old 03-25-2004 | 07:54 PM
Jordan Lee's Avatar
Jordan Lee
Default OEM Battery Alternative??
Good evening,
Is there a consensus regarding possible problems associated by using a non Porsche battery. Almost fell over today when the dealer quoted US$190.00 for the battery alone (no install) so was wondering if there is a kosher alternative? Vehicle is a ’96 993.
Many thanks,
J
Old 03-25-2004 | 08:01 PM
STLPCA's Avatar
STLPCA
Addict & Guru
Conventional battery: Interstate, Sears, Autozone
Sealed battery: Optima Red Top 75/35
After 4 good years from my Interstate, I've moved to the Optima.
Old 03-25-2004 | 08:12 PM
Pete Lech's Avatar
Pete Lech
Lifetime Member
The Optima Red Top ws a bolt-in for my car. Available for ~$100 at Costco.
Old 03-25-2004 | 08:47 PM
csertich's Avatar
csertich
I also replaced an Interstate battery with the Optima Red Top 75/35.
chuck
Old 03-25-2004 | 08:56 PM
Crimson Nape Racing's Avatar
Crimson Nape Racing
I also reopaced my factory battery with the Optima Red. It bolted right in, but i had to bend the big positive connection (from the car, not the battery)a little to get it to fit.
Old 03-25-2004 | 10:48 PM
mike cap's Avatar
mike cap
Jordan,
The Sears Diehard is a good option. Perfect fit. I think about $120.00.
Old 03-26-2004 | 12:37 AM
red1995streak's Avatar
red1995streak
Cruisin'
Ditto, the Optima Red Top 75/35. I also bought mine for about $100 at Costco.
Doug
Old 03-26-2004 | 01:06 AM
ceboyd's Avatar
ceboyd
yup.. my 96 993 has an optima red top also
Old 03-26-2004 | 02:07 AM
dale_loch's Avatar
dale_loch
When you get your Optima battery, be sure to protect it and your car forever.
Check this product out
http://www.prioritystart.com/ps_auto.html
Old 03-26-2004 | 05:18 AM
Monique's Avatar
Monique
If you do track time with your car, I suggest a gel battery. Will not spill.
Old 03-26-2004 | 06:24 AM
993Maineiac's Avatar
993Maineiac
I had very good fortune with the Sears International in my 944 and will probably be replacing mine this Spring. I have also read that the Porsche battery isn't all that good. At least a couple of disgruntled buyers in letters to the editor sections.
Al
Old 03-26-2004 | 07:59 AM
amfp's Avatar
amfp
I used the sears 48 with no problems. I also use a battery mat that helps if there is any acid gases that seep. That said I may try the Optima next as I do store my car for winter, but need to check the battery weekly.
Anyone here with Optima use the trickle charger ? If so any different to use than traditional acid batteries ?
Old 03-26-2004 | 08:38 AM
S3's Avatar
S3
Mye OEM battery died about 3 weeks ago. Porsche in Norway does not recommend OEM batteries - can't cope with winter conditions. Tried to source the Optima Red Top but could not find a supplier. Chose a Soennak Exide Millenium 3 STS. Got it yesterday so I don't know how it will perform over time. At least the car starts without problems.
Old 03-26-2004 | 12:26 PM
Jordan Lee's Avatar
Jordan Lee
Default Consensus
Seems as if the Optima Red is the way to go. On-line free shipping for less than US$100.
Thanks to all that contributed.
Regards,
J
Old 03-26-2004 | 01:31 PM
Sachin Misra's Avatar
Sachin Misra
Optima Red here as well.
Quick Reply: OEM Battery Alternative??
