993 Forum 1995-1998
the tiresome topic - Porsche 993 Tequipment handbrake alu lever
Old 01-12-2021, 05:01 PM
  #31
Dr. P
Dr. P's Avatar
Hey guys, speaking of these, does anyone offer leather boot replacement on the shift **** itself? It seems to be integrated/all one piece. I just purchased a '97 C2 and it came with the same handbrake and shift ****.
Thanks!
Old 01-12-2021, 05:21 PM
  #32
rsr91128
rsr91128's Avatar
Originally Posted by AOW162435
I decided I'd rather have the simple, all-black handle.
Erik,
Thank you for the offer - PM sent.
Andreas
You're welcome.
For fun as I was looking for that brake handle I remembered I had all of the literature for 993's so looked at how much they cost from Porsche back in the day... $850 new. Wow, surprised so many were sold.
Kicking myself for not pulling mine out a couple of weeks ago 😕.
Old 01-12-2021, 05:25 PM
  #33
rsr91128
rsr91128's Avatar
Originally Posted by Kika
Were there 2 different PNs for the Tequipment Aluminum 993 Shift ****? My car has the Y06 Option and looks like 911Jeff's in post #15, just mine is not CF.
The shifter **** in post #4 is clearly a different shape that I don't think was a 993 shifter.
Yes, 2 different part #s. Same price $850 😂
Old 01-12-2021, 07:41 PM
  #34
dannycf
dannycf's Avatar
Can anyone recommend a shop who can recover a 993 aluminum handbrake and have it look like factory work?
Old 01-12-2021, 09:13 PM
  #35
Gbos1
Gbos1's Avatar
Man $850 back then! Expensive!!!
Old 01-12-2021, 11:19 PM
  #36
Brig993
Brig993's Avatar
There is a lot of demand for these items. Given the commitment from Porsche with classic parts I wouldn't be surprised to see these reproduced at some point in the future.
Old 01-13-2021, 01:38 AM
  #37
boomboomthump
boomboomthump's Avatar
Same here. I didn't want any silver parts in my interior. Took mine apart, powdercoated the pieces and filled the lettering in white. Also upset some people, I'm sure.
In hindsight, I plan to redo the shift pattern in satin black to provide some contrast against the mini-wrinkle black. Will be making a run to the powdercoater soon enough.
YellowDieselGolf (01-15-2021)
Old 01-13-2021, 08:08 AM
  #38
stevensivak
stevensivak's Avatar
How do you get the cap off of the **** without damaging the alum surround?
or is that inevitable...???
So how much does the carbon **** and brake go for in mint condition?
Old 01-13-2021, 09:08 AM
  #39
boomboomthump
Definitely do not try to pry on it as it will not help and you will definitely destroy both aluminum parts on the shifter. To take it apart, follow theses steps:
  1. Remove the entire shift ****/boot from the car:
    • push down on left side of boot base to remove from two clips in console
    • slide base of boot to the left to "un hook" it from right side of console
    • angle boot base to remove it from opening in console base
    • lift boot up to expose allen screw at from side of shift ****
    • loosen allen screw to remove shift ****/boot from car
  2. With the shift boot/**** out of the car:
    • Use a heat gun to warm up the glue (epoxy) which is holding the shift pattern insert (apply heat directly to top)
    • Take a long, skinny screw driver and insert it up through the shifter shaft opening
    • You will want to move it around until you feel it enter a small hole in the larger aluminum piece and make contact against the bottom of the shift pattern. (see the circled opening in pics below)
    • With the screw driver held securely in that hole, bang out the pattern (gripping the underside of the shifter while holding the screwdriver and banging the screw driver base against the floor or workbench will make it pop off)
    • Once the shift pattern insert is removed, it will expose two screws which hold the second part to the rest of the shifter/leather covering
The following 4 users liked this post by boomboomthump:
archaeofreak (09-25-2021), ClassicAndy (01-15-2021), fnckr (01-13-2021), stevensivak (01-13-2021)
Old 01-13-2021, 10:36 AM
  #40
Brig993
Brig993's Avatar
Thank you for posting this. I wonder if one could make a "replica" of these parts once it is disassembled using the originals as the templates. With milling, CNC and 3D printing it seems like someone who has the resources or know how could. I'm not sure of the economics of it but as mentioned there seems to be demand and then they can be customized, finished and wrapped in materials of choice.
Old 01-13-2021, 12:08 PM
  #41
ToSi
ToSi's Avatar
https://rennlist.com/forums/for-sale...ake-lever.html
Old 01-13-2021, 02:55 PM
  #42
Kika
Kika's Avatar
Maybe purists might not "like it" but I think it looks great!
Old 01-13-2021, 03:05 PM
  #43
AOW162435
Seared
AOW162435's Avatar
I think that looks sharp!
Andreas
Old 01-13-2021, 08:09 PM
  #44
Gbos1
Gbos1's Avatar
That is a 996 shifter! Looks like the one in a 996 GT2 I drove awhile back.
Old 01-14-2021, 06:23 AM
  #45
ToSi
ToSi's Avatar
It's a 996 weighted **** attached to a 993 boot.
​​​similar to -> http://www.carnewal.com/products/993...eather-Shifter
Quick Reply: the tiresome topic - Porsche 993 Tequipment handbrake alu lever
