993 Forum 1995-1998
clutch problem
Old Jun 10, 2001 | 07:00 PM
Terry Lefco's Avatar
Terry Lefco
Question clutch problem
My 1996 C4 clutch has an intermittent problem. After a lot of driving, the top half of clutch travel is very soft and does nothing, but the bottom half does all the work so long as the pedal is depressed all the way to the floor. The problem goes away overnight!
I've already had the pedal assembly replaced so the next step is the slave cylinder, but I'm thinking maybe the pressure plate is getting weak when the engine gets hot. The clutch has 60,000 miles and otherwise seems fine.
Ideas?
Old Jun 11, 2001 | 10:53 AM
GeoT3's Avatar
GeoT3
Cool
after a long drive does your clutch make a creaking noise? mine does this after the car warms up and the noise goes away overnite. Try flushing the slave cylinder first see if there is an improvement.
Old Jun 11, 2001 | 08:39 PM
Terry Lefco
Post
No creaking but thanks for the suggestion.
Old Jun 12, 2001 | 02:16 AM
Ray Calvo's Avatar
Ray Calvo
Passed On
Red face
I am leaning towards clutch slave cylinder also; seems 50K is the life of these things.
Is this worse after you shut car off after a drive? With car parked in garage and engine off, operating clutch seems to bring this on? At same time, while operating clutch with engie off, open driver's door and stick head out door and towards bottom rear of car; see if you hear the cylinder. Generally, that's the time when I first started noticing the slave cylinder problem.
Old Jun 17, 2001 | 07:04 PM
Terry Lefco
Post
Both responder were correct about the creaking clutch. It's quite apparent with the engine off. I'll try a slave cylinder replacement which isn't that big a deal. Thanks for the comments.
Old Jun 28, 2001 | 10:42 PM
randy_h's Avatar
randy_h
Post
Terry,
Try replacing the fluid in your clutch system. If there is any moisture in the system, the pedal will be spongy. I had a similar problem on my 95 993 C2 and a fluid replacement solved the problem.
Old Jun 29, 2001 | 01:36 PM
hn's Avatar
hn
Post
My 95 cab with 52km has the same problem and based on the record, the previous owner did have the clutch bleeded at around 30km. Does it mean i need to replace the cylinder?
thx
Old Jul 3, 2001 | 11:06 PM
Terry Lefco
Talking
OK, my new slave cylinder seems to work fine. The car was great at a 3 day event at Jefferson Circuit and Summit Point. When the slave cylinder was replaced, it was necessary to bleed the clutch so I can't tell which was more important, but the combination was effective.
So who can tell me how to get more speed coming onto the front straight? Just kidding.
